07-14-2009, 10:28 AM | #1 |
Nv3500 to np205
Maybe somebody on here can help. I have an nv3500 out of 93 chevy blazer and I want to put an np205 t-case on it. I have a round pattern 205 off of a th400. My problem the t-case shifter hits the tail of the trans when i try to slide it on. Has anyone ever tried this combination or know of a place that makes an adapter?
67 Chevy K20 LWB Fleetside project 85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project 86 m1009 blazer, 6 in lift, 35's, driver 69 c10, 307, long bed, 3 speed, driver 07 Dodge 2500, cc, lb, cummins turbo diesel 00 z28 camaro, ls1, 6 speed, rarely leaves the garage |
07-14-2009, 06:43 PM | #2 |
Re: Nv3500 to np205
advance adapters would be your bet. google it.
07-14-2009, 06:46 PM | #3 |
Re: Nv3500 to np205
I looked there. They only seem to have adapters for the figure 8 pattern.
07-14-2009, 08:10 PM | #4 |
Re: Nv3500 to np205
can you post a couple pics of
it hitting? |
07-14-2009, 11:18 PM | #5 |
Resident of Here
Re: Nv3500 to np205
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
07-15-2009, 11:54 AM | #6 |
Professional Grade
Re: Nv3500 to np205
I wouldn't put an NP205 behind an NV3500 myself. In my opinion, they are too heavy for the aluminum housing on the transmission, and as you have discovered, the shifter is a problem.
I'd personally install an NP241 (89-91 for pass side drop, 89 for mechanical speedo) or an NP208.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
07-16-2009, 11:26 AM | #7 | |
Windy Corner of a Dirty Street
Re: Nv3500 to np205
x2 I have owned trucks with the NV3500. You will never be happy with that transmission. Very light duty, no granny gear, and the NP205 will be too heavy for the tail shaft as Russell stated.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
07-17-2009, 12:47 PM | #8 |
Re: Nv3500 to np205
I don't think the weight will be an issue. It has a mount to go from the t-case to the frame. As far as no granny gear, I don't think I need it, 4.56 gears should make first gear low enough.
07-17-2009, 12:55 PM | #9 |
Re: Nv3500 to np205
Not saying you are wrong, but I have found that even with 4.57 gears and even in 4 Low, compound low has its place. I guess it depends on how you use your truck. On steep or rough terrain it can help, or if you need to creep around a work site or something. Also, I don't have power steering so compound low is handy for maneuvering around.
Currently truckless, previous trucks: 67 K20, 87 K10 aka V10 & 72 C10 |
07-18-2009, 05:14 AM | #10 |
Re: Nv3500 to np205
The way I see it,why go through alot of hassle to put a transfer case that far exceeds the strength of the transmission when you can bolt on a tranfer case that matches the strength,like a 208 or 241?It might not be a bad idea if it didn`t have an obstacle.A 205 is definately overkill for that trans.Besides,a 241 has a deeper lo-4 to help compensate for the lack of granny gear.
07-18-2009, 09:39 AM | #11 |
Professional Grade
Re: Nv3500 to np205
Oh, and a 241 is rated for more input torque than a 205 is
07-20-2009, 08:26 AM | #12 | |
Re: Nv3500 to np205
02-10-2011, 09:01 PM | #13 |
Re: Nv3500 to np205
hey martindc1, what was the transfer case behind that nv3500? if you can remember lol
