Old 07-21-2009, 04:15 PM   #1
sixfour4x4
sixfour4x4's Avatar
64 swb body on mid 80s frame?
is it possible to use a mid-80s frame with a 64 swb body?
'64 4x4 Stepside 350/sm420, going L92 in the near future
'05 GTO that gets more attention than my truck
'69 Jeepster Commando that needs more attention than my truck
'71 wagoneer that gets less mpg than the gto
sixfour4x4 is offline   Reply With Quote
Old 07-23-2009, 12:47 AM   #2
Captainfab
60-66 Nut
Re: 64 swb body on mid 80s frame?
Yes but it will have a body lift when done. Unless you 'Z' the frame. Either way it's quite a bit of work. Why do you want to switch frames?
Old 07-23-2009, 01:28 AM   #3
sixfour4x4
sixfour4x4's Avatar
i'm looking for a 2wd frame. i've got a mid 70s k10 frame under my 64 right now. i have my jeep to wheel in, and now i want my truck to scream around town in. 33" tires aren't as easy to turn. and i've got a line on a 2wd 85 with a sbc400
Old 07-23-2009, 11:52 PM   #4
Captainfab
60-66 Nut
If your current frame is a mid 70's frame it should be the same as the '85 you're looking at.....aside from the 2wd to 4wd differences the frame is the same. So all the cab mounts should already be built. But as I posted yesterday, it's going to sit a bit high. The best frame to get for what you're wanting to do is a '63-'72 C10 frame, but apparently they aren't as easy to find in some parts of the country as they are here.
