Old 07-27-2009, 08:34 PM   #1
'68 K-10
'68 K-10's Avatar
trying to keep it on the road
I have an 84 swb 4x4 with 6" lift it has a lifted steering arm but not the pitman arm. I cant hardly keep it on the road sometimes it pulls side to side. it was toes out but i pulled that in and it helped but didnt fix it. i have 33x15.5x15 tires could that be the reason or do i need to change something? i was told to drop the sway bar and take the shims out from under the perches. any ideas?
'68 K-10 IN PROGRESS OF A FIRST TIME RESTO. ANY ADVICE IS NEEDED. I'M IN NEED OF SOME PARTS TRUCKS NEAR MICH. THANKS
'68 K-10 is offline   Reply With Quote
Old 07-27-2009, 09:28 PM   #2
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: trying to keep it on the road
6" lift will either require a steering arm (plus the "block"), .. s shaped drag link and the knuckle block (Like it sounds like you have) you may consider a hi steer kit.. I hear the objective, if you continue to use the drag link you have now, is to keep it as level with the ground as possible??
Eturnit3 is offline   Reply With Quote
Old 07-27-2009, 09:36 PM   #3
'68 K-10
'68 K-10's Avatar
I only have the u shaped steering arm that bolts to the knuckle that came with the lift. Where can i get info on different setups like the high steer
Old 07-27-2009, 09:50 PM   #4
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
there is good tech on this site if you search.. here is some info of the last histeer/crossover steer setup I saw http://67-72chevytrucks.com/vboard/s....php?p=3429761
Old 07-27-2009, 09:58 PM   #5
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
http://www.offroaddesign.com/catalog.htm
Old 07-28-2009, 01:59 AM   #6
dammitmitchell
the pollock
dammitmitchell's Avatar
hey how much play is in your steering,
i know i NEED a steering arm.. but the majority of my "slop" was from my powersteering not being "tight" there is a locked adjuster nut on the ps itself you can adjust in to firm it all up again
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 08-03-2009, 08:54 PM   #7
'68 K-10
'68 K-10's Avatar
not sure how much play i have but i will try to tighten that up and see if it helps
Old 08-03-2009, 11:00 PM   #8
JET4x4
Have you checked the wheel bearing nuts. I've seen them come loose on quite a few trucks and that really makes the truck wobble going down the road. Just my .02
67 Chevy K20 LWB Fleetside project
85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project
86 m1009 blazer, 6 in lift, 35's, driver
69 c10, 307, long bed, 3 speed, driver
07 Dodge 2500, cc, lb, cummins turbo diesel
00 z28 camaro, ls1, 6 speed, rarely leaves the garage
JET4x4 is offline   Reply With Quote
Old 08-04-2009, 06:47 AM   #9
OLDCHEV4X4
OLDCHEV4X4's Avatar
If it was mine, I would check:
Ball joints
tie rod ends
drag link ends
wheel bearings
steering box
steering box bolts
frame where the box mounts(cracks)
rag joint
Also, those 15.5" wide tires are a bear if the road has a groove worn in.
A steering stabilizer would help that.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-04-2009, 09:12 PM   #10
Oilbrnr
Oilbrnr's Avatar
Are you saying that on level smooth pavement it wanders, or when you go over bumps/dips? If it is the later, (which is probably the case) you really need crossover steering to correct. Any other slop in the system will be magnified by the bump steer.
Drag link should be parallel to the ground, but with that much lift you are going to feel it w/o a x-over setup.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 08-17-2009, 05:15 PM   #11
'68 K-10
'68 K-10's Avatar
The truck does fine on smooth flat pavement its when i hit a bump or get on a road that has grooves from the heavy semi's that it jerks left or right. it sounds like i need the cross over but i only take it in the sand or on the road there's not much rock around here and it doesnt see much mud so is it worth it? everything seems to be tight underneath. The sway bar bushings are a little wore out so that might make a little difference. i was told that if i lowered the sway bar that would help, any ideas on that? will the crossover steering correct the problem on the grooved road with the wide tires? Thanks for all the help guys.
