Battery draw?????
I got my 66 shipped in fron CA a few weeks ago and had to put a new alternator on it. It now puts out about 14 volts but the battery is dead after sitting all night.
I charged it up, and let it run for about 2 hours and shut it off. I pulled EVERY fuse and hooked a test light from the neg post to neg cable and its still lit up. I let it sit all night and its dead again. What do I do next? What could it be? |
Resistance is Futile
Re: Battery draw?????
I've had my '64 for 8 years and it still kills batteries after a week. 1/3rd of a volt draw that I havent found. I'm going to fix it with a new harness
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Cantankerous Geezer
Try disconnecting the alternator.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Parasitic load............... check for voltage @ your switches and the voltage regulator with the ignition in the off position. On my ignition switch my key comes out when its at the acc position.
Just here to tinker
![]() Join Date: Jun 2008
My Nova stumped me on this for awhile. It turned out I put the horn button in wrong and it was constantly grounding. Of course I had the actual horn out of the car so I couldn't hear it. That alone ended up killing the battery in about a weeks time of sitting.
I fixed the horn button, and the problem was solved! Little stuff like that is enough to make you ![]()
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
open circuits even if they are grounding will still consume power no matter how small.... it could be anything its just a matter of probing around when the power is off.......
I unplugged the plastic plug on the alternator and that fixes it. I have a wiring nightmare from the PO. The main positive cable from the battery goes to the starter and the hot wire from the alt. (10 gauge)goes to the starter. 1 wire goes to the electric choke and they have a few more wires spliced into that. I need to find the right way to wire everything and start over.
Is your truck stock? or has it had ''some work''? If its stock you should be able to get ahold of a wiring diagram fairly easy. If not......... it may be time for a wiring kit and just redo it all right..... I transplanted a harness from an 84 Suburban into my junk just for the age difference and blade fuses but it took a couple days to get it how I needed deleted alot too though
#9 | ||
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
