Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-08-2003, 06:53 PM   #1
78burban
Fuel problem or ignition problem?!?!
I just put a new cam in my 350 for my 81 c-10 it has a
brand new carburator and all new components for the
distributor (control module, rotor button,coil and
cap) including wires and spark plugs. now the problem im having is when i installed the cam started it up ran excellent let it run 20 mins varying the engine rpms to break the new cam in. i
drove it about 10 times down the street and back and
playing with the timing so i fianlly found the best
timing 8 btdc was running damn strong then all the
sudden it shifted into 2nd and just stalled out. got
it back to my house looked i couldnt find anything
wrong. started it back up had a hard time starting and
when i finally got it started back up it would start
then die after 5 seconds sometimes it will sound like its running on 3 cylinders if i give it any gas it will stall out. what do you think this could be. the truck has a brand new rochester rebuld
carburator on it. Please help me out
78burban is offline   Reply With Quote
Old 01-12-2003, 02:44 PM   #2
newage
fire
try dropping in another dist to see what happens if you have one laying aroundor borrow from a buddy
newage is offline   Reply With Quote
Old 01-12-2003, 03:43 PM   #3
78SilveradoSWB
78SilveradoSWB's Avatar
Talking Posting
Try posting this in the 73-87 Message Board instead of the Parts board. You might get more responses. Also, you might try the Engine & Drivetrain Board too.
78SilveradoSWB is offline   Reply With Quote
