I am in need of some advice. I am looking at a 1985 blazer so buy and put my truck on top of. I am aware that the wheel bases will not be the same and that i would have to cut the bed to make it fit. My question is how hard would this swap be and could i use pretty much everything off of the truck on my truck? I am going to look at the blazer sometime tonight. So any answers before that would be awesome.
Registered Chevy Owner
Re: 1953 chassis swap
You should be able to use most of the stuff from the blazer. Search around for s10 swaps and see what all they used. I know that there are a few guys that used almost everything. And cutting down the bed isn't hard to do.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
i passed on the blazer cause of the ifs front end. i am looking to lift my 53 instead of lowering it. my question is what frame has a solid front axle that i can put under the truck?
Are you looking for 4wd or 2wd (blazers come both ways)? By solid axle I assume you mean driven not tube or Ibeam?? If it is 4wd just do a search for "4wd conversion" and a bunch of previous threads will pop up.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
you can lift a blazer with IFS that is 4wd. Most late model chevys that are 4x4 are ifs. they lift easy and I understand that they handle better after the lift.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 Last edited by nickp51chevy; 08-07-2009 at 12:39 PM. Reason: messed up my point |
Tags |
1953, blazer |
