Old 08-07-2009, 11:25 AM   #1
Oklahoma
Help!!! ASAP Please
I have recently been laid off and need to get my truck back on the road. I just swaped out the old front suspension for a 79 front suspension. What I need to kow is, are there any spindles that will go on the new suspension that is 6 lug like what I had on it originally? that way I wont have to worry about new wheels and tires. Thanks a bunch guys.
Oklahoma is offline   Reply With Quote
Old 08-07-2009, 11:57 AM   #2
Oklahoma
Re: Help!!! ASAP Please
Woops, I ment are there any rotors that I can put on the newer suspension that is a 6 lug like I already have.
Old 08-07-2009, 12:07 PM   #3
70 Suburban
Rods
not for cheap... and not to replace cheap. if you do a seach here there a a few threads on it
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 08-07-2009, 04:23 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
They have them here for $75 each. http://www.truckandcarshop.com/trucks60_72/t60_115.html You will have to call to make sure they fit on late model spindles but I don't see why they won't
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-07-2009, 06:37 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I posted a link to a threAD a few weeks back that a guy used 87+ 3/4 ton 6 lug rotors, check on the threads that I started, it should be close to the top.
Old 08-07-2009, 06:38 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Yes. Many vendors sell them. Look at ECE. (Early Classic Enterprises)
They sell them for their 63-70 conversion kits,... but they will work on your spindles as long as the original rotors are the 1-1/4" thick version. Not the light duty 1" version.
Keith
Convert to disc brakes.
Old 08-08-2009, 12:05 AM   #7
Captainfab
60-66 Nut
Here is an alternative way of getting 6 lug disc brakes.
http://www.67-72chevytrucks.com/vboa...ad.php?t=35042
It would require some extra work, but if you're laid off you probably have some extra time. I guess it depends if you can acquire the needed parts on your budget. You might get lucky and find the parts in a wrecking yard.
