![]() Join Date: May 2005
My PG was making some racket as I shift tranny into gear, put it on my lift and pulled inspection cover off flywheel and 3 nuts and bolts came tumbling out all chewed up. When I replace them this weekend I need to know how much torque to apply to bolts so they stay put. These bolts and nuts mount the converter to the fly wheel. Anyone know the answer.......................Thanks.....Kirby
Sunburst C10!!!
Re: Tech Help
i just tightened the crap out of mine
if they're not lock nuts then put some lock-tite on them
Gage 1967 C10 Shortbed Stepside |
#3 | |
283 Drama Queen
![]() Join Date: Dec 2004
Re: Tech Help
Mac. ![]()
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
Re: Tech Help
check the flexplate for cracks also around the bolt holes
ron |
Registerd User
Re: Tech Help
This is one time I'll agree with Ron. If your bolts are chewd up then something else is to. If the flexplate is cracked it can start popping witch can sound kinda like a motor knock.
Re: Tech Help
Many thanks to all that responded I'll give it a good inspection before proceeding. Great advice as always.........Kirby
Ron maybe you can help me the torque converter seems to be about 1/2 in away from flex plate and when I attempt to bolt the two together the bolts are not long enough to connect to the nuts. Is the converter supposed to move forward to meet the flywheel? and if so how does one get it to move? Does it matter which ears go to what hole?.........Kirby
Re: Tech Help
if you lift the convertor up a bit and push it towards the flywheel it should go together. the is a pilot stub on the front of the convertor that should slip into the crankshaft to centre it. it doesn't matter where the bolts line up
ron Last edited by padresag; 08-15-2009 at 06:44 PM. |
Re: Tech Help
Many thanks Ron, will see to it on Sunday..................
