![]() Join Date: Sep 2006
to Hydroboost, or vacuum boost? That is the question....
I have a 63 C20 that I am installing a crossmember from a 72 C20 with front discs. I was planing on using a vacuum booster from a 75 C10, but remembered I have a Hydroboost off a 80's I think Van that had a diesel.
I would likely still swap the master cyl off of a 70's chevy, but am wondering what your experiences are with the hydraulic unit, and if its worth the trouble, altho it doesn't seem to be too tuff, especially if I get the add on bracket from CaptFab. |
Airport Bum
Re: to Hydroboost, or vacuum boost? That is the question....
Been toying with Hydroboost myself.
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
Resistance is Futile
I'm planning on this shortly myself. You cant argue with somewhere in the neighborhood of 1000psi pressure for braking IMO, IIRC.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Member of the longbed union.
Hydroboost is really easy to set up and you dont have to worry about loosing vacuum.
Vacuum boost is easier, but it really depends on your cam size on how much vacuum your motor pulls. Too much and you have to use pumps and other stuff for it to work. So my opinion, just send me the hydrobooster so I can use it on mine.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
Quote: "So my opinion, just send me the hydrobooster so I can use it on mine"
I KNEW SOMEONE WAS GONNA SAY THAT! ![]() |
I have used one in my 64 4 x 4 for the last 19 years. quite happy with it
ron Last edited by padresag; 08-16-2009 at 01:45 PM. |
.XIV. As of October 15th 2005 subscribing members will be the only ones permitted to post for sale and want to buy ads on any classified section of this site. All other rules of buying and selling still apply.
Its Deja Vu time again
If I had my way I'd go Hydroboost all the way.
Vacuum boosters put out between 1,000-1,600 lbs of pressure to your brake system. The hydroboost puts out between 2,400-3000 lbs of pressure to your brake system. This is basically giving you the power to stop the vehicle. It's the actual clamping pressure your calipers or wheel cylinders have to clinch onto the rotor/drum. Its on a Jeep, but the installation couldn't be much different for these old trucks. http://www.stu-offroad.com/suspensio...droboost-1.htm Last edited by kizer; 08-21-2009 at 05:41 PM. Reason: Removed link directly to a store. Looked kinda tacky and didn't want to look like a salesman. |
