08-15-2009, 04:23 PM | #1 |
454 motor mounts
will 73-87 motor mounts work on a 65 gmc that im trying to put a 454 into
1965 gmc Last edited by hahaudriveachevy; 08-15-2009 at 04:25 PM. |
08-15-2009, 09:36 PM | #2 |
Resistance is Futile
Re: 454 motor mounts
Yes...but you will most likely have to notch the frame rails back roughly 1/2'' or so to accomodate the correct angle. Very similar to the 67-72 frame with the factory relief for motor mounts. May have to drill a hole for the bottom of the mount on the x-member.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
08-15-2009, 11:54 PM | #3 |
60-66 Nut
Yes they will work. I would trim the top frame flange back a 1/2 inch or so starting in front of the motor mount brackets, going rearward and tapering off to nothing back past the bellhousing a little. I usually use a '73-'87 frame for reference. This will give you the extra needed room for either exhaust manifolds or headers. Also if you plan on running taller than stock valve covers, you will need to move the engine forward a couple of inches from the stock location. Otherwise you will need to modify the firewall to accomodate them.
08-16-2009, 12:38 AM | #4 |
thanks would the cpp motor mounts be easier to use
1965 gmc |
08-17-2009, 12:03 AM | #5 |
60-66 Nut
I've never used them, but I think you still have to trim the top flange of the frame to use them.
08-17-2009, 09:28 PM | #6 |
i think im going to try the ones from the brothers catalog http://www.brotherstrucks.com/prodin...number=ESM6372
1965 gmc Last edited by hahaudriveachevy; 08-17-2009 at 09:35 PM. |
