08-18-2009, 11:09 AM | #1 |
Axle spline
I took the axles out of my 64 to have drilled 5 lug and the bearing surface was bad. So I got a 65 long bed step truck and I got the axles out of it. The axles out of my 64 are 30 spline and the axles out of the 65 are a courser spline(didnt count them last night). Could someone tell me whats what here?
08-18-2009, 05:14 PM | #2 | |
Re: Axle spline
08-18-2009, 05:21 PM | #3 |
Re: Axle spline
Thanks. So more than likely someone put a early rear in the 65 and a 65-66 rear in my 64? And thanks for the info. I was wondering if I could just swap the spiders out.
08-18-2009, 05:56 PM | #4 |
Re: Axle spline
They sell 5-lug axle swap kits for the early rears & include the spider-gears as part of the kit. Because of the gears, the early kits are a little more expensive.
08-18-2009, 10:14 PM | #5 |
Re: Axle spline
Well I figured out the deal. My "64" is actually a 65. The man i got it and the long bed from told me the SWB was a 64 and the long was a 65. But he had them backwards. I just ran the vin and figured it out. I guess I will change spider gears since I have already got these 17 splines drilled.
08-18-2009, 10:38 PM | #6 |
Member of the longbed union.
Re: Axle spline
that's what I was going to say, They put the 17 spline in up to 64', Then changed it out in 65 with the 30.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
