Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-24-2009, 06:32 PM   #1
msgross
msgross's Avatar
air compressor, do these specs sound right?
seems like a lot of CFM for such a small guy, I need to use a die grinder, cutoff wheel and maybe a DA for short periods... thoughts? tank seems small but it's a decent price.
ChargeAir Pro Commercial Duty by DeVilbiss
GE 6.5HP 220vac Motor
12.2 SCFM @ 40PSI
10.2 SCFM @ 90PSI
Twin Cylinder, Oil Lubricated Compressor
Built in Regulator w/ Guages
20Gal tank
Comes with the hose in the picture
This is a great unit, not some oilless cheapy
$175 OBO
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-24-2009, 06:43 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: air compressor, do these specs sound right?
should be good for small air tools
i had one for years wish i never sold it
but i like the one i got now upright tank
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-24-2009, 07:49 PM   #3
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
That DeVilbiss pump does put out a lot of air for its size. I had one of those for years on a 30 gallon tank. I could shoot acoustic ceiling spray with it, and did so many times.
It's the perfect size for impact wrenches and maybe air ratchets. High-speed tools like die grinders use huge amounts of air though. That compressor will support them for short periods (like, say, half a minute or so), but then you'll be waiting around for a couple of minutes for it to pump back up. Probably doable if you're just doing some occasional weekend warrior stuff, but I wouldn't attempt to do an extensive body restoration with it.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 08-24-2009, 08:20 PM   #4
mbgmike
That sounds about right.
We are working on a compressor right now that puts out 44,000 psi I wish I had that for the shop but the motor is 3 times larger than the 10 cylinder compressor
mbgmike is offline   Reply With Quote
Old 08-24-2009, 08:33 PM   #5
msgross
msgross's Avatar
There is another compressor local for sale with an 80 gallon tank, he doesn't know the cfm though. He wants $250 which seems fair if it runs well...
I can get this little one for $140 but would like to run a die grinder for a little longer...
The Garage:
Old 08-24-2009, 08:41 PM   #6
BarryB
BarryB's Avatar
If your wanting to run a die grinder you'll need a bigger tank at least. You'll run that little compressor to death trying to run a DA. I tried running a DA with one that size. I ended up with a 60 gallon, and even at that when I use my DA it runs almost constantly. I'm now working on getting an 80 gallon IR two stage compressor.
Heck My 60 gallon will be up for sale once I get the 80 gallon in its place.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 08-24-2009, 09:59 PM   #7
fastwillie 696969
~Rest In Peace~
we call this beer time
Old 08-24-2009, 10:24 PM   #8
Lugnut64052
Buy as much compressor as you can possibly afford. Within six months you'll be wishing you had still more air.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 08-24-2009, 10:52 PM   #9
msgross
msgross's Avatar
I hear ya there, I already ditched the first compressor... now I need to run 220v to the garage.
The Garage:
Old 08-24-2009, 10:52 PM   #10
Atomsplitter
Atomsplitter's Avatar
I agree with Lugnut,
I started out with a 30 gallon 2 stage and it worked fine for my impact. When I bought my floor model sandblaster it didn't cut the mustard. Most continuous use air tools need a compressor that puts out at least 15 CFM. I bought a crapped out 80 gallon oil-less and frankinsteined a 3 cylinder single stage compressor to it and now it puts out about 18.5CFM (based on pump spec.s vs speed). I can use my sandblaster all day long, it refills to the high pressure setting while i'm using it and it never runs out of air. 2 cylinder high pressure pumps are great if you need the 175 psi but I get by with a high limit setting of 125 psi. Best tool I have in my shop.
My advice is to buy the highest CFM you can afford.
Atomsplitter is offline   Reply With Quote
Old 08-25-2009, 05:06 AM   #11
cdowns
cdowns's Avatar
get bigggg tank // sanders grinders blasters all love them
