laying low
![]() Join Date: Mar 2001
no heat!
My 2000 GMC has great AC but this week I attempted to turn the temp up on defrost and it only gets luke warm with the engine at full warm op temp. The heater hoses are both hot! Apparently the hot/cold blend door isn't operating correctly.
Anyone had the same problem and know how to get to that door actuator?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
![]() Join Date: Jan 2003
Re: no heat!
Double check your coolant. My stepdad's 04 5.3L had a similar issue and was low on coolant (the hoses were warm also). He had the issue with leaking water pump gaskets.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F Last edited by bwood; 08-25-2009 at 10:39 PM. |
laying low
Re: no heat!
Coolant level is full and the hoses are HOT!
