08-26-2009, 09:32 AM | #1 |
Muncie 4-speed
Is anyone running a Muncie 4-speed in our trucks? How is it set up? Where does the shifter come through the trasnmission hump? (Forward, rear, middle?) What type of shifter do you use? I have a lead on a Muncie for $450...
We are kicking around ideas for a build and want to know what type of non-granny 4-speeds we can use behind a built 350 (around 400hp). I think the NV4500 5-speed could work, but would like to have something a little more close ratio.
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
08-26-2009, 10:12 AM | #2 |
Re: Muncie 4-speed
Hurst makes a shifter and install kit just for putting muncies in trucks.
I have a super T-10, but the muncie should be identical - Here's pics of mine: |
08-26-2009, 11:32 AM | #3 |
The Older Generation
Re: Muncie 4-speed
I had one in my first '67 stepper but I used the stock column shifter and used a choke cable under the dash for reverse... LockDoc
08-26-2009, 09:06 PM | #4 |
70 Chevrolet=Obsession
Re: Muncie 4-speed
Here's mine. Sorry the pix is so dark but it was in the shade on a bright day. It's hard to see but mine comes out of the center of the hump far more forward that JIM_PA's does and yes, mine is factory original.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
08-26-2009, 11:01 PM | #5 |
Re: Muncie 4-speed
Here are some pictures of my 67 Pickup.
454, Muncie 4 Spd, High Hump Tunnel, Original Buddy Seats. The picture with the stick closest to the seats is with the transmission in 4th gear. |
08-26-2009, 11:57 PM | #6 |
My Carbon Footprint
Re: Muncie 4-speed
Not much....just a simple ole '69 ruck crushen M-22!!! Will not fit through the original hole. I got another high hump and custom cut mine to fit nice and tight. She's sweet!
08-27-2009, 07:13 AM | #7 |
Re: Muncie 4-speed
The shifter comes out the same place a 3spd floor shift conversion does.It`s 100% bolt-in swap for a 3spd.
08-27-2009, 11:40 AM | #8 |
Where's my beer?
Re: Muncie 4-speed
I have a really rookie question. I have a 3 spd converted to a hurst floor shift. If I go to a muncie 4 spd, since the shifter comes up in exactly the same spot, can I just reuse the actual chrome stick I have since it works with my bench seat?
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
08-27-2009, 12:11 PM | #9 |
Re: Muncie 4-speed
I think you'd have to cut it off, and drill 2 holes in it as the 4 speed shifters are completely different than a 3 speed.
08-27-2009, 12:27 PM | #10 |
Re: Muncie 4-speed
Will a 4spd work with a small hump floor? Or does it need to be converted to a high hump?
08-27-2009, 12:59 PM | #11 |
Re: Muncie 4-speed
I have a small hump. Are you talking about a car or truck 4-speed. I think it matters.
08-27-2009, 01:21 PM | #12 |
My Carbon Footprint
Re: Muncie 4-speed
Hey Jim....what's your shifter arm out of? I think mine was a car (Impala) with a bench seat and I had to do a little fabbin' to get it high enough to clear the seat.
Special K: So you're telling me that a 3 speed is that close to the driver's side? I didn't know that. Mine was a 4 speed and the hole was dead-center. Not even close. Seems like the rake and what not of your shifter arm might affect clearance. Then again....those factory holes are usually pretty big! |
08-27-2009, 01:56 PM | #13 |
Re: Muncie 4-speed
08-27-2009, 02:11 PM | #14 |
Re: Muncie 4-speed
You should be able to use the shifter "stick" on a 4 spd shifter, they are only held on by two bolts. The 4 spd shifters are the same way. Heck if you wanted to, you could use your 3spd shifter. But just like Locdoc, you'll have to have a choke cable or something to put it in reverse.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
08-28-2009, 06:17 AM | #15 | |
Re: Muncie 4-speed
The Hurst (Indy) 3spd shift levers bolt up different than the Hurst 4spds.I forget the series,Competition?I don`t see why they couldn`t be made to work.I have a tall Hurst 3spd lever I had in a truck that I hope to use.There is a just for our trucks application now.I know the 55-57 car bench seat levers work and I know of another that doesn`t have such a hook to it works.I just don`t know what it came out of.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-28-2009 at 06:22 AM. |
08-28-2009, 12:35 PM | #16 |
Re: Muncie 4-speed
What year model, transmission from car would work in our trucks?
Dave
68 C-10 Custom LWB 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
08-28-2009, 01:25 PM | #17 |
Re: Muncie 4-speed
ttt
08-28-2009, 01:37 PM | #18 |
Re: Muncie 4-speed
08-28-2009, 01:54 PM | #19 |
Re: Muncie 4-speed
Yep with the HP Hurst shifter
There really is no other choice.... 67 Chevelle was the motor tran donor
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD Last edited by 67chevemall; 08-28-2009 at 01:54 PM. |
08-28-2009, 02:15 PM | #20 | |
Re: Muncie 4-speed
I had just written a long drawn out explanation of this and just as I was about to hit submit......my electricity flashed off for a few seconds.
So, long story-shortened These car transmissions really do not have enough span between low and hi gear. The close ratio box is only 2.2-1 and the wide ratio is only 2.5-1. Where your typical truck transmission, not even counting that super-low first gear, has about 3.5-1. If you gear the rear differential high enough to run at hi-speed on the highway, it will be a slug in the city....and forget about hauling or towing. If you gear it low enough to be "fun" to drive in town, it will run out of breath on the interstate. You can't have both
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
08-28-2009, 02:36 PM | #21 |
Re: Muncie 4-speed
Right - this is definitely more for high performance/cruisers, rather than heavy towing.
I do fine with the 295/50/15's and 3.73's, and I can still haul more weight than I would ever attempt to haul with it, but I wouldn't do it all the time. A car transmission just isn't made for it. When I need tires again, I'll probably go to a 275/60 but that won't change things much. |
08-28-2009, 02:46 PM | #22 |
Re: Muncie 4-speed
I don't do much hauling with mine,mostly trash to the dump.
08-28-2009, 03:10 PM | #23 |
Six in a row makes it go...
Re: Muncie 4-speed
Remember, this is also a Muncie 4-speed
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
08-28-2009, 03:18 PM | #24 | |
Re: Muncie 4-speed
Yes, but that is not what the original poster was refering to....and although I was "corrected" like this one other time, that is not the generally accepted "name" of the big truck transmission.
Most of them are called by number SM420, SM465, etc. Besides, you wouldn't have to ask or "adapt" to use a factory availble transmission.
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. Last edited by LONGHAIR; 08-28-2009 at 07:52 PM. |
08-28-2009, 03:22 PM | #25 |
motor exploder
Re: Muncie 4-speed
Tremec TKO all the way - 3.27 1st gear, .68 OD 5th, shifts like butter, and tough as nails! with that 400hp and a set of 3.73's, you'll never stop smiling!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
