Old 09-01-2009, 07:44 PM   #1
ortega
454 swap from my k5 to my v6 c10
here are a couple of pics. i'm taking the 454/400 out of my 2wd k5 into and dropping it into my 85 v6 c10. i'm almost done, i just have a couple more things to do, the only problem is my driveshaft doesnt fit. i'll try to get some more pics of where it is at right know soon, but in the mean time here are the ones i have on my computer right know. i have to get it done asap though because thats my daily driver.
ortega is offline   Reply With Quote
Old 09-02-2009, 04:18 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: 454 swap from my k5 to my v6 c10
Sweet! What about the blazer?
tvblazer78 is offline   Reply With Quote
Old 09-02-2009, 08:23 PM   #3
ortega
i have a 5.3 and 4l60 out of an 05 with 40k miles waiting to go in. i just have to finish with the 454. everything is done with the c10 thanks to my brother in law, i just need to take my drive shaft to get lengthened a bit.
Old 09-02-2009, 09:05 PM   #4
tvblazer78
Low & Fast!
tvblazer78's Avatar
Cool!!
You will have to post a build on it too..
Old 09-02-2009, 09:36 PM   #5
ortega
yeah for sure, i'm not taking to many pictures of the c10 i'm just trying to get it done as soon as possible and i'll be bringing it back to my house from my sisters, so i'll have it outside if i want to take pics of anything. i'll be taking my time with the k5 and try to take pics of everything.
Old 09-03-2009, 12:52 AM   #6
ortega
i forgot to mention that one of the header bolts was broken inside the head, i never noticed because i parked the truck as soon as i bought it and when i would turn it on i heard a leak but i always thought it was from the collector. anyway would i be able to take it out with a screw extractor?
Old 12-06-2009, 08:45 PM   #7
ortega
here are some more pics of the truck. i haven't done much to it in a while but i just got a complete interior that i'm gonna put into it including ac and power doors.
in this picture you can see a pretty big gap between the door and the cab, i cant figure out to get this closer. the rest of the door lines up pretty good
Old 12-07-2009, 03:15 PM   #8
Damien
Damien's Avatar
You need to loosen the bolts on the door side of the top hinge and push to door in. you will probably have to loosen the bottom bolts a little. leave them tight enough so the door won't move on its own.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 12-08-2009, 03:54 AM   #9
ortega
Alright cool, I'm going to try that tomarrow if it dosent rain
Old 12-08-2009, 08:49 AM   #10
menace121978
menace121978's Avatar
cool build man! motor looks good in there. cant wait to see the blazer build!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 12-08-2009, 10:40 PM   #11
ortega
i would have liked to have seen the blazer build too, but i bit off more then i could chew with both trucks. now the blazer and 5.3 are gone. i guess now i can focus just on the c10 since its not my daily any more
Old 12-10-2009, 10:18 PM   #12
ortega
i had a little time to play with my truck today. this is what i did, cut the hole for the wires and mount the right side door. the gaps look better on this side then the drivers side, and thats with out any adjustment. i just threw them on but i used the hinges from the donor, so i might take the drivers side door off again and use the donor hinges this time.
