09-02-2009, 02:01 AM | #1 |
Best rivet removal system
Okay when I was workin on my truck painting the under engine frame and all I noticed that just about everything is riveted to the frame, even the clutch deelio. Since my new Motors auto and I need a whole different cross member for the trans I will need to remove these to get them outa the way, plus I'd like to bolt everything in for later removal if wanted.
So what's the best way to remove these annoying rivets? |
09-02-2009, 02:27 AM | #2 |
resident oilfield trash
Re: Best rivet removal system
I used a cut off wheel on a grinder and cut the heads off and then knocked them out with an air chisel
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
09-02-2009, 02:35 AM | #3 |
can I tuck tractor wheels?
we just did like 20-30 of them tonight the easiest way was use a FLAP WHEEL DISC )search on ebay for picture. then we just pushed them through with a hammer and punch.
My build page.... http://67-72chevytrucks.com/vboard/s...d.php?t=347666 |
09-02-2009, 02:47 AM | #4 |
We used a grinding wheel attached to a drill to grind the heads off, no air chisel here, so we used a drill and 1/4 bit to remove some metal from the center and then knocked them out with a punch.
Personally, I would leave everything else riveted if possible, stronger than bolts, and after you remove the 10 rivets holding the manual crossmember and clutch bracket, you may find they are a real pain to remove. And a tip - if you have access to a torch, after the rivets are out of the crossmember, use the torch to remove a 4-6 inch piece from the center of the crossmember, makes it much easier to remove.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
09-02-2009, 04:15 AM | #5 |
Thanks guess I gotta go buy a grinding wheel, I got air tools but not much metal fab tools. I may just have to alter the stock cross member for the trans, the one from the car probly won't work, it's even a weird shape, not symerrical at all. I even had to bend the frame of the car with a pipe wrench to get it out. The rubber mount on the car trans just mounts with one bolt stickin down through and the actual mount bolts to trans were unreachable, but the bottoms flat so it should be easy to mount in the truck.
09-02-2009, 07:24 AM | #6 |
I would strongly suggest that you do not even try to fab up a cross member for that, used automatic trans crossmembers are easily available in the parts section on this board or most any junk yard. You will get the geometry right and it is a bolt in deal with no hassles at all.
09-02-2009, 07:27 AM | #7 | |
Better yet, buy one grinding wheel and one flap disc. Do the first rivit with the grinding wheel and the next one with the flap wheel. I bet you never put the grinding wheel back on your grinder. Another tip is to hold the punch with a vise grips. I tend to whack a punch a heck of a lot harder when my hand isn't near the impact zone.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
09-02-2009, 07:50 AM | #8 | |
09-02-2009, 08:03 AM | #9 |
the way we did mine was a air grinder then punch them out with an air chisel..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
09-02-2009, 09:08 AM | #10 |
since my air chisel isn't the strongest I used a cutoff wheel, made an "X" on the rivet head (like a phillips screw) then air chiseled the four little pieces off... might have to punch out the remaining piece with the air punch but it made quick work...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
09-02-2009, 10:42 AM | #11 |
Never Ending Projects
Exactly what I did and it worked great.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
09-02-2009, 10:48 AM | #12 |
Damn, I am surprised no one has mentioned the fast method to doing rivets
An air hammer with a flat chisel blade on it. It takes about 10 seconds to get a rivet off and then punch it out with a punch bit on the same air hammer after you have sheered all the heads off the rivets. I could do 100 of them in 30 minutes or less. |
09-02-2009, 12:45 PM | #13 |
X2. Use ear plugs though. Air hammers are LOUD!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
09-02-2009, 01:08 PM | #14 |
I didnt have access to any of those things or electricity , So I used a metal chisel and a BFH to remove my trans cross member.
Not the best way but ya use whats ya gots. |
09-02-2009, 01:14 PM | #15 |
09-02-2009, 03:14 PM | #16 |
No kidding I think I would give up
09-02-2009, 03:19 PM | #17 |
Just Not Low Enough!
what do you guys say to an air hammer?
woops my bad, just read a few posts above!!
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. Last edited by BAGNDRAGIT; 09-02-2009 at 03:21 PM. |
09-03-2009, 03:41 AM | #18 |
LOL air hammer lets ask the cops that showed up tonight because we tried to use one.... its so loud that the neighbors all called to complain... not that this is the first time they have been out since the blazer got into the garage... actually the 4th..hahaha
09-03-2009, 04:07 AM | #19 |
This forum rules, guess ill go to ace my next paychek. Just got done usin a dremmel with cuttin wheel on the nuts holdin the bottom of the bumper on. I have had ZERO luck with these stinkin carriage bolts, I won't use them again from now on. At lead they were easier to get to than the ones holding the radiator support to the frame, those really sucked.
09-03-2009, 07:36 AM | #20 |
I like my large electric angle grinder (4.5") with a cutuff wheel, that's if you can get it close enough to the bolts...
09-03-2009, 10:35 AM | #21 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-03-2009 at 10:35 AM. |
09-03-2009, 11:32 AM | #22 |
Timing. 8:00 pm-- good. Midnight-- bad
09-03-2009, 12:33 PM | #23 |
4AM = really bad... ask sourkrout about our all night roof removal!
09-03-2009, 09:03 PM | #24 |
I got one of these to help remove rust from my frame. Man are they tough. I think I'll try the rivet removal thing. I have one left over from my spare tire mount crossmember that I removed.
-Scott- |
