Unfinished Project Club
![]() Join Date: Jul 2005
linking compressor
I have a craftsman 5 hp 25 gal compressor which stopped working right, so I went out and bought another one. This one is a Huffy 6.5 hp with a 30 gal tank.
my guestion is, if I link the two compressors in tandum, would it be benifical in any way. thanks Randy
![]() ![]() ![]() ![]() ![]() ![]() ![]() Handle every Stressful situation like a dog. If you can't eat it or play with it, Pee on it and walk away. 1996 Dodge Intreped ES Nice car great on gas ![]() 1993 Jeep Cherokee. Looking for a swb chevy 73-87 |
Re: linking compressor
The 5HP one doesn't run any more? If so and you intend to only use the tank as "additional" air storage capacity, you would actually be doing yourself a disfavor. Your new compressor would work harder, run longer, supply moister and hotter air causing premature motor failure as well as additional problems for your airtools.
thanks...I wasnt sure
as I somethmes I use my tools a lot and the compressor never seems to have a chance to shut down. So I was just thinking, maybe that might work I know I could have gotten a larger one but its all I could afford. any thanks again
you can take the motor and pump off the old one and with a few fittings turn the tank into a portable air tank// good to fill up a couple of flat tires when dragging projects home
![]() Join Date: Sep 2005
i have 2 compressors at work a champion witha 5hp motor and a 80 gallon take and a ir compressor and they are both linked together been that way for about a year and no problems yet they run longer only on first start up of the day but they do not cut on nearly as much as the single compressor did by it self
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 09-05-2009 at 04:28 PM. |
#6 | |
Redefining LowBudget
I ran a set up like you want to do for years before I bought my bigger one that I have now....all I can say is pull air from the none working comp tank as the air will cool in there collecting a ton of moisture ( so drain regularly).....you comp may run longer on start up but it it will also rest longer before starting for the next cycle......like you said we have all run them for hours with a DA sander......
the big question to everyone is when was the last time you changed the oil in your compressor ? |
The way I wanted to set it up was, working unit, to non working unit to tools is that what you mean
Thanks Randy
![]() ![]() ![]() ![]() ![]() ![]() ![]() Handle every Stressful situation like a dog. If you can't eat it or play with it, Pee on it and walk away. 1996 Dodge Intreped ES Nice car great on gas ![]() 1993 Jeep Cherokee. Looking for a swb chevy 73-87 Last edited by lvschevytrucks; 09-05-2009 at 08:07 PM. |
#9 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
double post sorry
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 09-05-2009 at 08:52 PM. |
we one run compressor at a time at work one as a storage tank and change the oil in there every 6 months
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Son of a gun
Two compressors hooked together can work slick, takes some adjusting to get it right though. You don't want them starting at the same time. Adding another tank to the system can provide extra air on hand, but won't help where you would need more air continuously, like sandblasting. Still would need more CFM's for that.
Bill BEATERS ARE NEATER |
