Old 03-24-2002, 04:26 PM   #1
1968GMC
love my truck
1968GMC's Avatar
Post need advice on instaling performer intake
I'm mentaly geting ready to instal my intake in a week or 2. On the intruction sheet, they say not to youse the end seal. Has anybody ever use the end seals and did they work? I dont care about using the rtv cilicone but I bought some anyway. I will ask more ? as I get closer to instalation.
1968GMC is offline   Reply With Quote
Old 03-24-2002, 04:30 PM   #2
Lumpy
2 tons of fun
Lumpy's Avatar
Post
I just did a cam swap and dropped my performer intake on using the end seals with no problems. Just a dab of silicone where the gaskets and the seals meet. Good Luck.
67 Chevy,short/fleet,350,4-speed,lowered 4x2,small window,P/S,edelbrock intake/carb,HEI
Three Rivers, Ca
Pic at: <A HREF="http://community.webshots.com/album/29068416etoBoEninp
" TARGET=_blank>http://community.webshots.com/album/29068416etoBoEninp
</A>
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cam 274H
Three Rivers, Ca
Pics at: http://www.cardomain.com/id/lumpy454
Lumpy is offline   Reply With Quote
Old 03-24-2002, 04:35 PM   #3
BIG ORANGE
BIG ORANGE's Avatar
Wink
Throw the seals in the trash and use the rtv aply about a 1/4 thick on the ends let it set afew minutes and then place the intake on,tighten bolts from center out in a cross pat.Hope this helps.
BIG ORANGE 1971 SUBURBAN
1970/90-Little Buck's Truck (ONE DAY)
USED TRUCK PARTS 4 SALE
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 03-24-2002, 04:44 PM   #4
69 longhorn
Post
2nd that,I never use the end seals.....toss em in the garbage ,& use some high temp RTV........69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-24-2002, 05:05 PM   #5
BUXMAN66
go bucks!
Lightbulb
YEAH, i did the same pitchin'the end seals. the is a gasket former that is real simple to use,i used it on my performance pkg. from edelbrock, it's called "rite stuff"it comes outta a can like cheez wiz . make sure you go up into the corners good(dont glob) at the intake gasket .overlapping the intake gasket w/the "can of cheez wiz".they dont make it any more easier than that!
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 03-24-2002, 07:16 PM   #6
pinky350
Post
Toss the end gaskets in the trash. they will slip out of place and you will not know it until you start to leak oil. A good high temp silicon is what you want to use.
And I always put a thin coat around the water jackets. But this is just me.
pinky350 is offline   Reply With Quote
Old 03-24-2002, 07:19 PM   #7
704x4
Post
we need a post that is dedicated to "the right stuff"
that is the best gasket maker ever invented
it may cost about $15 per can but a can will do a complete engine
you can put it on anything slap it together and drive it with no leaks and no dry or setup time
thats my testimonial to "the right stuff"
70 3/4 ton 4x4
FOR SALE
Greene, IA
704x4 is offline   Reply With Quote
Old 03-24-2002, 08:07 PM   #8
conman
Post
Throw the gaskets in the trash like rest of them said. But on the two center bolts either side of carb use the same rtv on those bolts. It will keep oil from eventually easing up through those bolts and making that new intake look ugly. Also you might want to up rtv around the water jacket openings. Good Luck!
Fayette Alabama
conman is offline   Reply With Quote
Old 03-24-2002, 10:03 PM   #9
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
yeap use hi temp rtv.... i did no leaks no worries
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
