Old 05-21-2002, 10:26 AM   #1
koobie
Post sm465 bulletproof?
I think the input shaft on my sm465 just gave up its ghost. Just chatters when put in gear. Anyway- I'm about to pull it and have a few questions for those that have done it before. Is it easier to remove the tranny and the transfer case as one unit or individually? Can the sm465 be rebuilt or do I need to find a donor? If rebuildable, any idea on cost and what to expect at the tranny shop? Finally, any tips on removal or installation would be appreciated.
72 Sierra Grande 4x4
crate 350/4spd
koobie is offline   Reply With Quote
Old 05-21-2002, 11:20 AM   #2
Blazer1970
Blazer1970's Avatar
Post
I drop the t-case and tranny separately. I would block the motor up under the oil pan, and remove the cross member first, before the t-case. This makes it a lot easier to get to all the bolts. leave the t-case adapter bolted to the tranny when you pull it out. All of the parts for the 465 are available, and it can definitely be repaired. If it needs a shaft or gears (anything other than bearings or seals), it may be cheaper to buy a whole tranny at the junkyard than to buy the new parts. These trannies are pretty easy to find used.
Blazer1970 is offline   Reply With Quote
Old 05-21-2002, 11:32 AM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
Post
I will be dropping a 465 out of a 2 wheel drive 72 GMC this next week. If you need anything let me know. That's about all the help I can be on the subject.
1971 C-10 Suburban
1972 C-10 Suburban
1969 XL Galaxie Fastback
1968 Galaxie 500 Fastback
1974 SCOUT II
Montrose, Minnesota
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 05-21-2002, 01:11 PM   #4
koobie
Post
Thanks burb. I'll let you know. I work fairly close to you and have been meaning to check out your fleet anyway.
crate 350/4spd
Old 05-21-2002, 02:28 PM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
Post
I work in Plymouth now, NE corner of Hwy 55 and 494 if you ever need anything (w/o having to go 20 miles further west).
1971 C-10 Suburban
1972 C-10 Suburban
1974 SCOUT II
Montrose, Minnesota
Old 05-21-2002, 07:06 PM   #6
Scrub
Collector of rusty Items
Scrub's Avatar
Post
Trick number 2713
To get the old pilot shaft bushing out:
Pack the cavity where it is with heavy grease and then get something the same diameter as the pilot shaft and hit it with a hammer. The grease will work like a hydraulic jack and push the bushing out. You might have to repack the cavity once or twice, but this has always worked for me.
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
