Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 09-20-2009, 04:17 PM   #1
cLaWz
Mud/Sludge/Dirt from Hell (McDade, Tx)
When my wife bought the truck I noticed the dirt buildup on the bottom of both the engine and transmission but didn't think it was a huge deal. Was used out on a ranch, it's going to get dirty I thought. Crawled under to do some cleaning to help track down a leak today, started but almost immediately had a my god moment.
This mud/dirt/incarnation of evil is from hell, theres no other explanation. Ranch is out in McDade Texas and I wondered why my wife always called it the "evil red dirt", now I know. This stuff is EVERYWHERE on the underside of the truck and is rust colored to boot. I went to start brushing and scrubbing and you would think this stuff was some sort of epoxy coating! I would rather clean up tar then this stuff! I spent 2 hours with an assortment of degreasers, brake cleaner, carb cleaner and all manners of brushes and scrapers to try and get this stuff off. In that 2 hours I barely made a dent into the removal of said incarnation of evil.
I do not own a power washer but was curious as to how safe it would be to rent one hose the underside of the truck like crazy with it. Assuming I need to be wary of any wiring, fittings, linkages, etc but otherwise I presume it would be safe correct? If so, any recommendations for cleaners? Just about the only thing I can think of left to try against this stuff. I am NEVER going mudding out that way!
cLaWz is offline   Reply With Quote
Old 09-20-2009, 06:38 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Mud/Sludge/Dirt from Hell (McDade, Tx)
Wear clothes you intend to throw away . That Texas red dirt won't come out of your clothes . It actually will help with rust prevention . You have a big job ahead of you . I have put the truck in the yard and set a garden sprinkler under it and let that run with just enough water to wet the bottom of the truck . This will soften it up , pre pressure washer . Hope that helps .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 09-22-2009, 05:29 AM   #3
vegaschevy
I was going to suggest this, you can actually let the spirinkler run for a couple hours and it will fall right off.
vegaschevy is offline   Reply With Quote
Old 09-22-2009, 10:04 AM   #4
cdowns
cdowns's Avatar
putty knives and butter knives are excellent tools for scraping things off engines and undercarriges
