09-26-2009, 10:47 AM | #1 |
input on this setup
I was looking for ideas to do the rear,I saw this and it looked simple.Is this a good setup,won,t let me upload the pic but is a 2 link where the link goes from the rearu bolts and connects to the old spring hanger
09-26-2009, 11:00 AM | #2 |
Re: input on this setup
Like this....
09-26-2009, 11:04 AM | #3 |
09-27-2009, 10:24 AM | #4 |
ya like that,is it ok
09-27-2009, 10:30 AM | #5 |
There are those that think they're great; there are those that think they're not so great. I looked into this set-up for my 74, but decided against because of the drastic amount of pinion angle change they are capable of as the suspension cycles through compression/extension.
09-27-2009, 10:41 AM | #6 |
so what did u decide to go with
09-27-2009, 12:30 PM | #7 |
I drove on an Ekstensive 2-link for years in my 97 x-cab and never had one problem with it.
Just this summer I swapped the panhard for a watts link. Worked like a charm.. I never changed the air pressure while driving... Raised it to drive height, layed it out at a show... |
09-27-2009, 03:26 PM | #8 |
I left the flip-kit + shackles in & added a home built air-over-leaf so I could tow my trailer.
09-28-2009, 10:24 AM | #9 |
09-28-2009, 11:05 AM | #10 |
Look here, page-15 starting w/post #366.... http://67-72chevytrucks.com/vboard/s...d.php?t=223158
I followed this logic but mine has the upper home-made bag plate welded to the bolt-in c-section & the lower bag mount is the original leaf spring pad on the top of the rear end housing. My bags are bolted in from the top & float on the bottom using an allen bolt in the bottom of the bag to locate it on the spring perch. Before I did mine, I PM'd Kevin to inquire about how the dbl convoluted worked for him. He said he ran it w/o air psi when he didn't need the extra capacity so you don't even know they're there. I agree.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-28-2009 at 11:07 AM. |
09-28-2009, 02:46 PM | #11 |
thank you
