Old 09-27-2009, 06:23 PM   #1
SnS C10
SnS C10's Avatar
Just bought a 79 2wd Blazer!
hey everyone just picked up an all original drivetrain 350/th350 1979 factory 2wd chevy blazer. has original buckets and console with back seat. power windows and locks, a/c, flip kit in rear and drop spindles in front. its my new daily driver but im gonna resto it while driving. i will take progress pictures soon
SnS C10 is offline   Reply With Quote
Old 09-27-2009, 08:54 PM   #2
Conundrum
Conundrum's Avatar
Re: Just bought a 79 2wd Blazer!
Cool, where are the pics?
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 09-28-2009, 09:14 AM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sweet!
tvblazer78 is offline   Reply With Quote
Old 09-28-2009, 01:07 PM   #4
SnS C10
SnS C10's Avatar
ok here you go i will be taking pictures and updating the progress as time and money allow. hope everyone enjoys- shaun
Old 09-28-2009, 01:55 PM   #5
tvblazer78
Low & Fast!
tvblazer78's Avatar
Thanks for pics, what are you going to do to it?
Old 09-28-2009, 02:38 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Looks like a decent project, nice buy!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-28-2009, 03:14 PM   #7
SnS C10
SnS C10's Avatar
thanks for the comments. first off it was sitting under a tree parked on the street for the last 10 years. some how it was given a new battery gas and it fired right up. just found out it had no oil or air filter. so i added some oil and gave it a new filter and cleaned up the carb. its running good now. cant even feel the tranny shift through the gears. The master cylinder is leaking but other than that the brakes work great. Next up is getting the rear window to go up. it went down but the switch is not turning the motor in the other direction. after that a nice cleaning of the interior, im going to reverse the flip kit and add 2" shackles and remove 1 leaf spring. then, im going to cut the exhaust and weld on my flowmaster 40. after that, block sanding the body panel by panel and spraying with satin black. this may turn into a build thread if thats ok thanks guys for looking
Old 09-28-2009, 04:45 PM   #8
Conundrum
Conundrum's Avatar
Thanks for the pictures.
At least yours has a switch, the one I just picked up doesn't have one and I got ahold of a manual tailgate for mine.
Old 09-28-2009, 05:59 PM   #9
SnS C10
SnS C10's Avatar
well i tested the switch and its working fine and i hooked up 12v to the power motor and it works fine. so there is a problem with the wire somewhere on its journey to the front of the truck. i am going to bypass these wires and rewire it to the switch in the dash. Then all will work! next this week possibly cutting exhaust for flowmaster and reversing the flip kit- we will see
Old 09-30-2009, 09:50 PM   #10
SnS C10
SnS C10's Avatar
just an update i got the rear power window working. new plug wires on the engine and removed the a/c unit. also welded on a new flowmaster exhaust and chrome tip. engine is running a little rough. all cylinders are firing timing is on and no exhaust or vacuum leaks. going to replace the cap and rotor and put in some new spark plugs on the weekend. found out the rear end has air shocks and what do you know they still hold air. nice smooth ride all around for being this low on a static drop. here are a few exhaust pics...
Old 10-02-2009, 08:47 AM   #11
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sweet looks good, hope you find out what going on with the motor.
Old 10-04-2009, 01:14 AM   #12
SnS C10
SnS C10's Avatar
engine is fine. did a compression check and 150psi in all cylinders. adjusted carb and timing now runs great. next week im picking up an edelbrock performer manifold and 650cfm carb so it should sound great then. also i added a new master cylinder and bled all the brakes it stops on a dime! next update will either be body work with black primer or adding the edelbrock engine parts
Old 10-04-2009, 11:57 AM   #13
tvblazer78
Low & Fast!
tvblazer78's Avatar
Cool get us some pick when you get the new stuff on..
Old 10-16-2009, 01:05 PM   #14
SnS C10
SnS C10's Avatar
ok just an update. i removed the original q-jet and intake manifold plus all of the smog crap that goes with it-egr, charcoal canister...and so on. i put on a edelbrock performer eps endurashine manifold with a performer 650 electric choke carb-runs prefectly smooth now, has more power and doesnt smoke on startup anymore. tell me again what all of the smog crap does? haha
next up for the engine is edelbrock water pump and valve covers. removing the old cruise control unit as well as a/c condensor and general clean up. if anyone wants the condensor/air compressor/carb or intake, let me know i will let it go for very very cheap. thanks for looking
Old 10-19-2009, 07:56 PM   #15
SnS C10
SnS C10's Avatar
updated pictures
Old 10-20-2009, 12:48 AM   #16
SBTork
Garage wrench
SBTork's Avatar
Very cool project. Im glad you got it running right then put on some good lookin stuff. It will look even better with the valve covers, water pump, and cleaned up a little more.
What's the time frame for bodywork and paint?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 10-20-2009, 01:11 AM   #17
PBFAB.COM
PBFAB.COM's Avatar
Won't you need to re-install all the smog/emmissions controls in order to pass inspection for registration? I know AZ is pretty strict... and I know CA is worse!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-20-2009, 12:19 PM   #18
SnS C10
SnS C10's Avatar
it just passed smog in august of 09. in two years when i need to pass again i will put it all the smog crap back on-it just runs so much better now. no smoke on startup no rough idle no hesitation and most of all no dying out on cold starts
