Old 09-29-2009, 02:29 PM   #1
texanidiot25
Eat My Rust
texanidiot25's Avatar
Vent window swings loosely, what broke?
My vent window used to be pretty weak, wouldnt stay open at 50+ mph like the passenger. Then a few weeks ago it went totally limp, it just pivots freely. I was wondering what holds it open? Is it a bolt or clam in the door, or the rubber seal that keeps it open?
texanidiot25 is offline   Reply With Quote
Old 09-29-2009, 02:32 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Vent window swings loosely, what broke?
there is a stud with a spring for tension on the bottom of the Vent Window. I will see if i have one to show you in my parts pile.... I borrowed a pic from the site, kind of dark but you can see the stud on the botton with the spring for tension, Yours could be really lose, or possibly broken.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-29-2009, 04:41 PM   #3
texanidiot25
Eat My Rust
Can that spring be tightened?
Old 09-29-2009, 04:59 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Yes, you have to pull out your vent window to do this.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 09-29-2009, 05:02 PM   #5
Rack Man
Is it possible to tighten that by just removing the door panel and reaching up there?
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 09-29-2009, 05:09 PM   #6
leddzepp
Moderator
leddzepp's Avatar
You can give it a try, but I'd think you would cut up your arms doing so. The window and regulator might also get in the way. I have the panels off of one of my trucks now, so I'll check it out tonight and see if it can be done.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-29-2009, 05:51 PM   #7
my67chevytruck
Under Construction
possibly with a swivel and a long extension....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-29-2009, 05:52 PM   #8
Rack Man
...Ummm...yea...I forgot about that part....This is the result of dropping a socket down in the door....it was stuck pretty good and I started to panic as I was home alone....so I just ripped it out of there!
Old 09-29-2009, 05:55 PM   #9
my67chevytruck
Under Construction
Rackman,,
buy a extendable magnetic tool......
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-29-2009, 06:07 PM   #10
Rack Man
Originally Posted by my67chevytruck View Post
Rackman,,
I own one....Ok, actually three or four of em....It was a "spur of the moment" deal...LOL
Old 09-29-2009, 06:28 PM   #11
Thealien
Thealien's Avatar
There are locking tabs that fold over that nut. You would have to unbend them to tighten that nut. This will make a tight space seem even tighter, good luck.
Old 09-29-2009, 06:31 PM   #12
leddzepp
Moderator
leddzepp's Avatar
I knew there was another reason I pulled them out to do this...
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-29-2009, 06:45 PM   #13
Thealien
Thealien's Avatar
I just took an old beat up one apart for a learning session before I attempt a restore on a pair, only reason I remember
Old 09-29-2009, 08:30 PM   #14
texanidiot25
Eat My Rust
I'm skinny.. I think I can get up there. I need to pull my door panels off to silence some rattling linkage, this will add onto the todo list. Anyone have a close up pic so I know what I'm doing with out looking at it?
Old 09-29-2009, 08:37 PM   #15
Thealien
Thealien's Avatar
From this
THREAD
Old 09-29-2009, 09:05 PM   #16
texanidiot25
Eat My Rust
Oh that really sucks.
Old 09-29-2009, 09:21 PM   #17
Thealien
Thealien's Avatar
I "tried" to brake it to you gently?
Old 09-29-2009, 09:24 PM   #18
texanidiot25
Eat My Rust
I'll just have to attempt to pry it back or dremel it. I can reach up there, but that bolt is more protected than I thought.
Old 09-29-2009, 11:12 PM   #19
Thealien
Thealien's Avatar
It should bend easy enough. They aren't that strong.
Old 09-29-2009, 11:16 PM   #20
leddzepp
Moderator
leddzepp's Avatar
Be careful you dont break it when taking it off. A lot of times the nut is rusted on there, and PB Blaster is your friend.
How is the rubber? Now is the perfect time to pull them out and rebuild them completely.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-29-2009, 11:26 PM   #21
texanidiot25
Eat My Rust
Don't have cash to put new rubber, but it needs it if I go threw a car wash. Which I don't, so, I don't need rubber.
Old 10-02-2009, 06:55 PM   #22
Thealien
Thealien's Avatar
Don't forget to let us know how you made out.
Old 10-02-2009, 11:46 PM   #23
texanidiot25
Eat My Rust
Haven't had time to mess with it. Getting a '75 Camaro retuned on it's new motor this week. Slowly getting it ready to whup another friend's '67 Mustang.. ha
