Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-15-2003, 09:25 PM   #1
Lester
Weiand BBC Team G Intake
This intake is in perfect condition and can be used on only 366T or 427T BBC engines. A 750-850 Holley or Edelbrock works well. I used this with a Crane 272/284 515/510 hydraulic cam with standard rockers and a 750 Edelbrock without any mods with no problems. Started easily, ran well when it warmed up, edgy and pulled VERY hard from 2500 thru 5500 when the stock ignition signed off. The cam carb and intake did not require a torque convertor change.
Features
2500-7900 RPM power band
Tall deck (truck) blocks ONLY
Oval port cylinder heads
Single plane/open plenum design
Manifold is machined for standard deck height distributor
Square flange carburetor mounting
Carburetor Recommendations
750 - 850 Holley HP
Specifications
Height - frt. 6.13", rr. 7.69". Shipping weight is 28 lbs
Lester
Lester is offline   Reply With Quote
