Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-29-2009, 06:47 PM   #1
koolky
67-72 Addicted
koolky's Avatar
94 s10 rear spring sag?
A few months ago I bought a 94 s10 2.2L 5 speed for a daily driver. The rear end is lower than the front and im wondering if the rear leafs are just tired? Also, I often put have loads in it (scrap, yard waste, 1 ton axles for my 72 K20, etc...) Can I get springs that are heavier that I can just bolt in to solve the sag problem and get the weight rating up? Lastly, will adjustable air shocks solve any of this? Thanks
koolky is offline   Reply With Quote
Old 09-29-2009, 08:03 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 94 s10 rear spring sag?
Air adjustable shocks will help. You can add weight support leafs. Check with www.jcwhitney.com for the best prices.
My Jimmy sits level. If I add any weight the rear sags. Trailers cause the most sag. I plan on replacing the springs, adding a support leaf or block.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
