Old 05-21-2002, 08:26 PM   #1
Mudhuny
Post BB swap
I am new to this group, so bear with me. I'm looking to swap a BB into my 72 3/4 ton 4x4, w/ 350 & 4-speed, and am wondering what kind of problems, etc, am I looking at. I've heard that the bell housing will mount up correctly, but am wondering about motor mounts and cooling capacity. Any help will be greatly appriciated.
Mudhuny is offline   Reply With Quote
Old 05-21-2002, 10:54 PM   #2
Desert Rat
Desert Rat's Avatar
Post
Ok i have done this swap a few times not on a 4x4 but they never came with a BB so you will use your existing mounts.but you will need all the pulleys,brackets,fan shroud,cooling depends on your radiator if your truck is a AC truck id use existing radiator.My truck was original SBC with AC i put in 402 live in AZ and temp gauge barely moves.
Desert Rat is offline   Reply With Quote
Old 05-21-2002, 11:00 PM   #3
Scrub
Collector of rusty Items
Scrub's Avatar
Post
Dang,
I wish we had a search function. This topic was covered pretty well about a month ago.
I've never done it, but here is what I remember from the thread.
The distributor will bang on the firewall unless you:
Put a body lift or..
Bang a dent in the firewall or..
Move the engine forward, thus needing two new driveshafts, 4x4 Linkage work, Fan shroud, move the transfer case cross member, clutch linkage etc
The easiest was to bang a dent in the firewall for the distributor.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 05-21-2002, 11:04 PM   #4
Mudhuny
Post
Thanks for the help. I figured that it was probably covered before I came to the group. The main thing I was wondering about was if I could use the existing motor mounts, or if I needed to weld/fabricate some new ones on there.
Old 05-22-2002, 01:36 AM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Post
You can use your existing motor mounts. I have done this swap in my 4X4 Blazer. I have a 402 BB in it. You will have to dent the firewall for the short only valve covers because the tall ones will not fit unless you cut holes in your firwall. Or you will have to do a 2" body lift to get the clearence you need. WES www.ClassicHeartbeat.com
Click (Here) to visit our on-line catolog.
E-mail me WEHEPP@attbi.com
72 BB Chevy Blazer
72 BB Chevy Short Fleet
72 SB 3/4 Ton 4X4
72 SB 1/2 Ton SWB 4X4
70 BB Chevy Short Step
70 SB Chevy Short Fleet
69 SB Chevy Short Step
68 SB Chevy Short Step
68 BB GMC Long Fleet
67 GMC 1/2 ton Panel
"Founder" Classic Heartbeat Pickup Club
Olympia, Washington's "Home For Wayword Chevys"
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
