Old 05-21-2002, 11:09 PM   #1
Bandit
Post timing
What kind of timing should I use on my 350?
RV cam HEI ignition, I think before the engine was disassembled the timing was about 6 degrees BTDC
If there is any more info you need, just reply!
Bandit
Bandit is offline   Reply With Quote
Old 05-21-2002, 11:12 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
With an RV cam, it will probably be best pretty close to stock. Best thing is an educated guess, then a test and tune at the track, or back road with a stop watch. (or a G-tech if you have that kind of $$...those things are sweet)
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-21-2002, 11:34 PM   #3
69 longhorn
Post
I agree, you shouldnt be too far from stock setting with a mild cam. Ideally,if you set the timing where the eng starts & idles the best,you should be fine. To experiment with a timing light,you might try bumping about 2 degrees at a time & test run.......pull a few hills & listen for spark rattle. good luck..........69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-22-2002, 12:38 AM   #4
bigjimzlll
bigjimzlll's Avatar
Post
did he mention he has 10.5-1 CR...i think he might have to back off from stock a smidge
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 05-22-2002, 01:38 AM   #5
Bandit
Post
So what are we talking the, like 4 or 5 degrees???
Bandit
Old 05-22-2002, 07:16 AM   #6
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Post
For along time people have been talking about RV cams. They are very very close to stock and not as radical as most people make them out to be. Set the timing to stock. RV cams were popular back in the day, but with todays technology you can get a better cam. I have a XE 256 and my timing is back 6 degrees.
Ben
67 Fleetside Custom C-10
SBC 350 .030 9:1 comp.
Comp Cams Extreme Energy XE256H-10
Carter AFB 600
Edlebrock performer intake
Screw in rocker studs
Oversize valves
Scat 350 crank
Everything balanced within one gram.
Marine grade plywood bed(looks awsome)
67Fleetsidedream is offline   Reply With Quote
