10-04-2009, 03:21 PM | #1 |
Auto Meter gauges in the factory bezel?
I have a question on how to replace the factory gauges on my '71 with auto meter gauges using the factory bezel. I have seen pictures of this done but do not know what size gauge or weather or not the bezel had to be cut. There is very little room between gauge openings, therefore gauge size would be criticle. If any one here has done this and can remember what size gauges to use please let me know. Thanks, Shawn
10-04-2009, 04:09 PM | #2 |
Re: Auto Meter gauges in the factory bezel?
i used 2 5/8 and 5" autometer Ultralite
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
10-04-2009, 05:00 PM | #3 |
That is great help, Thanks Nuke 1
10-04-2009, 10:01 PM | #4 |
2WD Jimmy
These are Super Comps. Putters Classic Concepts did them.. Hes a great guy and a board member.
10-04-2009, 10:37 PM | #5 |
wat has to be done to these to get them to inset into the bezel for a stock look?
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
10-05-2009, 07:44 PM | #6 |
That is really sharp. Kind-of the look im after. Any info on the gauge sizes?
10-05-2009, 07:49 PM | #7 | |
Now we have to replace his and fix it. He is a member and did it himself, maybe he will post. We are just waiting for him to bring it back to fix it. Last edited by mbgmike; 10-05-2009 at 07:52 PM. |
10-05-2009, 08:35 PM | #8 |
Here are some threads with part numbers and build instructions...
http://67-72chevytrucks.com/vboard/s...d.php?t=110613 http://67-72chevytrucks.com/vboard/s...d.php?t=188607
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-04-2009, 04:43 PM | #9 |
Here are mine. Sport Comps. I removed the bezels on the smaller gauges and used them as spacers to get the face of the gauge against the factory bezel.
11-04-2009, 05:14 PM | #10 |
PROJECT 7DEUCE
where did you get that clock wow!!!!!!
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-04-2009, 06:11 PM | #11 |
Never Ending Projects
That looks great, one of the better ones done. Agree, the clock just sets it off.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
11-04-2009, 06:26 PM | #12 |
Thanks. I made the clock from an 80's GM clock, a piece of sheet metal, plexiglass and some ABS pipe. I made the face with a graphics art program. I had to learn the program, so it took a loooong time to create. Once I had it looking good, I took it to a print shop and had them print it on vinyl. Probably some copy right infringment issues here, but there was nothing else availble.
11-04-2009, 08:04 PM | #13 | |
11-04-2009, 10:33 PM | #14 | |
As for copyright, as long as you using this for personal use and not selling/promoting it, you can basically do anything. Great job again!!!
11-05-2009, 12:56 AM | #15 |
just some cutting on backside of bezel
" DRIVING " = The "Whoa Sh*t" look on your face when you mash the throttle.!! |
11-05-2009, 03:37 AM | #16 |
"THE GREEN GOBLIN"
111stony Nice Gauges. What size gauges did you use Big & Small that is the look I am looking for I don't want the gauge to come out the front just sit flush to the back wall of the gauge cluster, against the factory bezel.. Thanks Pablo
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
11-05-2009, 04:46 AM | #17 |
what size are the speedo and the tach?
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby |
11-05-2009, 10:56 AM | #18 |
Pablo/Wilson - The big ones were 5" and the small ones are 2 5/8". I cut up the small ones to get them to fit up against the bezel.
11-05-2009, 11:49 AM | #19 |
There's FAQ thread that tells how to do this. It includes a list of part #'s. The center gauge is 3 3/8", they are difficult to find. Here's a picture of mine.
11-05-2009, 01:52 PM | #20 |
Thread Killer!
I know you asked about the factory bezzel but I did a little variation of it. I had a panel cut out and epoxied it to a factory bezzel. That way I did not have a big gauge in the middle.
I used traditional series gauges and added a dual needle air gauge for my bags that is very similar but with a white face.
71 Cheyenne SWB LS1 and auto. http://67-72chevytrucks.com/vboard/s...d.php?t=256470 _____________________________________ If it's worth doing, it's worth doing twice... _____________________________________ Don't Mistake Honesty for Negativity... Last edited by 71BB_LWB; 11-05-2009 at 01:56 PM. |
11-05-2009, 02:07 PM | #21 |
does that horn button work? LOL
nice setup
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-19-2011, 06:13 PM | #22 |
07-04-2011, 12:52 AM | #23 |
Sweet looking panels, I need to do mine.
07-04-2011, 11:01 AM | #24 |
this company seems to have a gauge panel set that looks pretty close to the stock look coming from the back.http://classicinstruments.com/
07-04-2011, 02:52 PM | #25 |
Laid Back
one of mine
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
