New weight.. 3,620 with me in it.
Just want people to put info up for people.. Might help them..
Previous weight 3,850 with a half tank of gas. 2,050 front (52.7%) and 1,800 rear (47.2%). This was with my tailgate down (added weight to it so there is a leverage ratio) Still have the steel front, but no hood/springs, and inner fenders cut out. Swapped the bench seat for Summit Racing plastic seats. Made my front crossmember but swapped intakes (plastic to alum) this was technically a wash as I shaved 25lbs but added 25lbs. New weight 3,620 with a full tank. 1,880 front (51.9%) 1,720 rear (48.1%). This was with my tailgate up so no extra leverage. Not exactly sure how I got +230lbs out from the last track outing. by my math I only come up with about 150lbs.. But I'll take it!!
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
THE DAMN YANKEE
Re: New weight.. 3,620 with me in it.
nice what #s you runnin now? any new video?? would like to see some.
phipp |
Phipp.. Unfortunately I'm out of work right now and my mortgage is more important than spending $250-$300 going to the track. it's 198 miles away, so it's a bit of an expense.. Someday..
My very late street night pass on my fairly accurate G-tech (with in .1 and 1mph at the track) says I a 7.68 @ 96.5mph in the 1/8 on a spinning slow 1.89 60' So it should on a good hook go 11.50's maybe on motor??
good deal every little bit helps. these old tanks need all the help they can get to get moving
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
![]() Join Date: Dec 2008
my dad got a truck down to 2800 pounds but we used a smoke wrench on anything we could find we also took out the radiator support and used angle iron to hold the fenders straight, if you really start looking around you can cut weight if you think about it the windows in that thing with the tracks weigh about 30 pounds a piece. you can take more wright out get it on a lift and look under it there is extra bracing everywhere just look real hard.
What year truck?
What trans and motor?
1966 swb with a small block in it add 170 pounds if it is a big block
you can trim the inside of the fenders,doors, you can cut the floor and use aluminum in its place you just have to take your time and think also that front wind shield is heavy you can by lexsan in 4x8 sheets. there is easily 100 pounds on the frame that can be trimmed |
i have been working on finding weight to cut. The 3,620 (3,420 with out me) has the following done..
Alum block and heads (LS1) Trans is rather heavy being an OD 4L80E, I'm sure there is a 100lb saving using a glide. Bench seat replaced with Summit racing seats No front bumper Alum wheels (15x12 315/60/15 drag radial rear / 15x6 front with a 195/75/15 front) No hood Inner fenders cut out Alum radiator Gas tank replaced with a plastic fuel cell in the back of the bed Heater removed Roll pan in rear The glass front i plan on putting on i think will cut another 40ish lbs. I need to swap tailgates out as i have about 100lbs added to it. I have a tow hitch made from 2x4 that probably weighs 30-35lbs that needs to go I would like to go with a Mustang 2 front when I have a job again. No idea on this. I have a brake booster that needs to come off (alum brake master) 10-15lbs? When i can, I'd like to make a new frame from either 2x3 or 2x4 .120 wall. Windows are definately something I have thought about, but the truck is still driven on the street and get's parked out side on a regular basis. More ideas would be great..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 10-21-2009 at 02:20 AM. |
Oh sorry our was just a drag truck it just looked like a daily driver
our gas tank "fuel cell" was in the back and the battery but seems like eventually you will get down to about 3100 good luck and have fun with the smoke wrench |
How are you weighing it? Track with a scale? Around here I've heard you can weigh in at a big truck scale, just have to pay something and they would let you weigh in. What's the weight of your truck in stock form? I have a '91 S-10 and I want to start getting the weight down.
digital scales like the ones that dirt track people use I don't know the original weight we started cutting on it 30 minutes after we got it it took us two weeks to trim it all down
i normally weigh mine at a local truck scale and at the track when I go..
#13 |
Mean Green
Damn super that's RAD. Your are going to be all over that roll bar mark.
![]() If I could put my pig on that type of diet, I also would be smashing my way into the lower 11's How much did you want for those front springs? |
#14 |
the diet helps alot, mine weight 3450 with me in it. small block and a stick. all steel body. rad support chopped down alot, no inner fenders, plastic seats, no gate or rear bumper, plastic cell. etc.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
#15 |
THE DAMN YANKEE
super 73, sorry to hear about the work situation! this economy needs a boot in the ass to keep it going. NOT GETTIN TO POLITICS WITH ANYONE! I hope you find employment soon. v/ phipp
#16 |
Thanks Phipp.. i hope i do too. I want to go racing..
BTW, I have been experimenting with front and rear springs again. since the recent weight loss, i think i might have a spring that will work just as good as the moroso, but it will come from a junk yard for less money, BUT, your front weight would have to be very close to mine. I can tell you one spring that is a little too soft, but the right length, a Jeep Cherokee 6cyl front spring.. 17 3/4' long, but about a 160lb rate. Puts my truck a touch tooo low. The LaC shafts are literally 1/2-3/4" off the ground right now. If your front weighs 1,650, they would probably be on the money.. Gonna try the grand cherokee next.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 10-28-2009 at 01:27 AM. |
#17 |
Jeep Grand Cherokee V8 springs are money in my truck.. 17 3/4 inches long, guessing 190-200lb rate (I didn't measure compressed ride height so not 100% sure).
#18 |
![]() Join Date: Jul 2008
73 I hope we drop to around 3300 or so with the fiber hood,only thing else is to start cutting,You know what I mean,It may happen this winter,I don't want to sell it since I bought it new but may if I can get the old nova at 600 bucks,And I just bought a new hood!!!!!!!!!!!!!!!!!
Built chevy tuff! ![]() |
#19 |
Please let me know if I can help you once things are semi finalized..
#20 |
Boosted Member
Mine weighs in at 3950 without me in it.
LWB Fleet Air bag suspension (no tank or compressor) steel roll pan Iron block, aluminum head LSx 4L80E Looking to put her on a diet this winter, and add some more power ![]() ![]()
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
