Old 01-17-2003, 09:01 PM   #1
tim m
Rear wall thickness
Is the rear wall under the window and behind the seat 2 pieces? I want to mount my amp there, but I dont want to put a screw through the cab.
1970 k10
1971 C10
Gilbert Az
tim m is offline   Reply With Quote
Old 01-17-2003, 09:14 PM   #2
jmanz69
Careful, they attack...
jmanz69's Avatar
Directly under the window for about 5-6 inches it is. After that it is one, and you will put a screw through the cab!! You could glue a piece of wood to the wall with construction adhesive and then you would be able to screw your amp down. Or even under your seat depending on how big your amp is. Good luck!
jmanz69
jmanz69 is offline   Reply With Quote
