Old 10-21-2009, 12:09 PM   #1
jmanthony65
jmanthony65's Avatar
02 Ext cab window removal
Has anyone pulled one of these out? I need to replace my driver's side one due to someone breaking into my truck... I need to pull frame and all because where the window connects to frame its broken. Thanks....
jmanthony65 is offline   Reply With Quote
Old 10-21-2009, 10:08 PM   #2
BP68
BP68's Avatar
Re: 02 Ext cab window removal
The glass can be removed from the frame on the hinged side. The rubber surround on the glass has tabs that lock/snap into the plastic frame.
If the frame is not damaged you can swap on a new glass.
If the frame damaged, it is bonded in like a windshield and you will need to have a glass company replace it for you.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 10-22-2009, 10:06 PM   #3
jmanthony65
Of couse its the plastic frame piece(my luck)... And I was so hoping it would be a U-PULL it job i could do but I guess not... Thanks for the help..
