Old 10-27-2009, 02:41 PM   #1
bills59
'56 GMC Long to Short bed
What would be involved in making a 1956 GMC 1/2ton long bed into a short bed?
bills59 is offline   Reply With Quote
Old 10-27-2009, 02:59 PM   #2
1lowdiesel
1lowdiesel's Avatar
Re: '56 GMC Long to Short bed
some cutting... welding... rewiring... cussing you know the normal custom stuff.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 10-27-2009, 03:01 PM   #3
63 & 64 Bowties
and a few others
You mean just the bed? Are you putting it on a different frame?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 10-27-2009, 03:02 PM   #4
bills59
The truck had a 8ft flatbed on it however I was wondering what would be involved in putting a short box on it or just throw on a long bed
Old 10-27-2009, 03:09 PM   #5
1lowdiesel
1lowdiesel's Avatar
ha i was just messing around.
if the truck had a pick up bed on it then they put the flat bed the mounts for the bed should still be there.
to run the SB you would need to take a section out of the frame then weld it back together. shorten the drive shaft or just get a new one. relocate fuel tank behind the axle. shorten brake cables and lines. remount the short bed.
xtremediesel.com
Old 10-27-2009, 04:55 PM   #6
OrrieG
OrrieG's Avatar
Can't you just relocate the spring perches and rear crossmember farther forward and trim the back rails too. The frame rails are parallel. Depends on your level of confidence, welding ability and if you want to see the welds and fish plates.
OrrieG is offline   Reply With Quote
Old 10-30-2009, 05:39 PM   #7
Norselander
Clunker Farm, Proprietor
Norselander's Avatar
The easiest thing to do is remove the difference in wheelbase from the frame rails just behind the cab going back. No tank relocation is necessary if you intend to keep the tank in the cab. The driveline will need to be shortened and you -may- wish to adjust the pinion angle of the rear axle.
This is a pretty straight forward mod on '55-59 trucks because the frame rails are essentially parallel and in the same plane (where you cut). On earlier trucks the frames grew narrower towards the front and on older trucks the frames dipped below the cab.
Fish plate and box the cut.
Drew
Chief Junk Jockey
Norselander is offline   Reply With Quote
Old 10-30-2009, 07:05 PM   #8
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
Theres a guy out in Sacramento that will do it for $1500. If you want his number PM me. He cuts the frame and bed. I think all you have to do is the drive line and reflare the brake lines.
kalirodding is offline   Reply With Quote
