Old 10-28-2009, 07:03 PM   #1
harshard
Question Bed cutting question.
In most of the threads I've seen on here where someone is cutting their bed down from long to short they all seem to be using a small square type of clamp that holds both bed pieces together. What is this clamp and where would I find them? I am planing on cutting my bed down in the future and would like to have all the needed hardware in advance. Any info. would be great, thanks Shawn
harshard is offline   Reply With Quote
Old 10-28-2009, 07:12 PM   #2
jay6891
Car Knocker
jay6891's Avatar
Re: Bed cutting question.
eastwood sells them
http://www.eastwood.com/intergrip-pa...-set-of-4.html
Work really well, IMO
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 10-28-2009, 07:43 PM   #3
cdowns
cdowns's Avatar
harbor frieght has same as eastwood at fraction of the price//called buttwelding clamps
Old 10-28-2009, 08:33 PM   #4
mclairmo
Reading the term "buttwelding clamps" immediately transported me to those days where my buddies and I would watch Beavis and Butthead and drink bear all day long and still not get enough of either.
mclairmo is offline   Reply With Quote
Old 10-28-2009, 10:37 PM   #5
kev2809
low n' slo
kev2809's Avatar
lol, that does sound funny. i was wondering the same thing on the name of these. do they work better than cleco pins?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-28-2009, 11:02 PM   #6
my67chevytruck
Under Construction
my67chevytruck's Avatar
hmm. I thought what you had pictured were clecos? are you referring to the 90 on the end....
x2 on harbor freight, i bought mine there as well....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-28-2009, 11:06 PM   #7
kev2809
low n' slo
kev2809's Avatar
what i pictured were cleco pins, right? i was wondering if they were better than the buttwelding clamps..
-_--_--_ _________
Old 10-29-2009, 10:41 AM   #8
Rokcrln
Rokcrln's Avatar
With cleco's you have to have an over lap in the panel and that leads to rust in-between the panels. The butt clamps let you but weld the panels together so when is all said and done you can treat both sides of the weld for better protection.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-29-2009, 10:49 AM   #9
JJanzen
JJanzen's Avatar
Kevin,
When you are cutting down a bed floor, do you weld the top or bottom side or both? How much time would you estimate it takes to weld the bed floor and grind it. I know you are a lot faster than most but in talking to a local welder, he had no idea how long it would take and would only give me an estimate of time and materials. Thanks. Joel
Blue72
Red72
JJanzen is offline   Reply With Quote
