05-22-2002, 12:19 PM | #1 |
2 1/2" Ramshorns
where to buy at the best prices,ready to trash the headers. any other suggestions.
1972 3/4 4x4,14bolt locker rear, dana44 lock right front, sm465, sb 400, blazer tank,dual batterys,3"lift,32-9.00-16 super swampers daily driver other trucks 1972 1 ton dually 4x4,454 4 spd,,235-85-16, flat bed front and rear winches, rear gas tank and under bed gun safe.tilt wheel |
05-22-2002, 12:26 PM | #2 |
67-72 Addict!
Are these better than headers?. My dad just removed a set of these to replace with aftermarket headers.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-22-2002, 01:37 PM | #3 |
8mag,
do you need the ones with the alternator mount? or have you eliminated you brackets to the exhaust bolts? You can get brand new ones from various supporters of this board, as well as a GMPP dealer. 70c10, Better is a relative term. Do they provide better performance than headers, not usually. Do they perform better than headers for noise reduction, maintenance and longevity....usually. It depends on what your requirements are. I'm willing to bet that 8mag is tired of leaks or burned up starters. Those are generally the strongest opposition to headers. Just my .02 cents. ------------------ '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. Way too much money and time..But it's a hobby.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
05-22-2002, 01:50 PM | #4 |
Registered truck nut
I ran into another aftermarket company out of California last weekend. "Truck Shop" www.truckandcarshop.com The prices and quality was excellent, on the stuff I bought, but I haven't mounted anything so we'll see. In their catalog they have 2 1/2" ramhorns for $135 each. I'm not sure if this is a good price, though
------------------ MOUNT VERNON, WASH. STATE GOT MY BASES COVERED -Big and bad 70 CST Blazer -71 K5 Blazer, 350, 4spd, 2" lift, 35" BFG mudders, Camo, -Work in progress 72 SWB -72 Cheyenne, lwb, 1/2 ton, 4x4, V8, 4spd. -71, 3/4 ton, 402/400, Custom Camper -69, 2wd, ST6, auto, ghetto lowered, 3/4 ton, LWB, "BOMBER" -69 Chev. short narrow 4x4 -69 Chev., lwb, utility trailer, 35" tires, Add or Delete Daily
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
05-22-2002, 02:00 PM | #5 |
Senior Moment
I've used the Truck Shop a lot. They have good prices and a good inventory. I bought thier complete set of BB AC brackets and they had them in stock, not sure if there OEM but they do look like them and for me if it works I dont care about Originality. Any way thats me, check em out, I like em and they seem to have EVERYTHING and at fair $$
------------------ Steve's 70 CST 02 Burb (wifes Truck) www.picturetrail.com/70CST
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
05-22-2002, 02:12 PM | #6 |
Check with the various discount GM Performance parts suppliers. http://www.paceparts.com http://www.sdpc2000.com . The least expensive 2 1/2" rams horn is part # 3797901. This manifold will work on both sides. There is a generator mount that needs to be cut off at least the passenger side for firewall clearance. It is very easy to cut off. These are straight down dump manifolds, so they work good on 4X4s, not sure on 2WD trucks. There are no angled dump 2 1/2" rams horns.
------------------ Tim [This message has been edited by Blazer1970 (edited May 22, 2002).] [This message has been edited by Blazer1970 (edited May 22, 2002).] [This message has been edited by Blazer1970 (edited May 22, 2002).]
Tim |
05-22-2002, 03:04 PM | #7 |
There is 2 kinds of headers, ones that leak and ones that are going to leak.
------------------ 72 GMC Burb barn door 4X4 350/350 PS PB Tilt 62 Chevy Nova Convertible 64 Chevy II V8 Loaded Wagon VW Offroad buggy 84 700SC Honda Nighthawk
72 GMC Burb barn door 4X4 350/350 PS PB Tilt ( gone but not forgooten) 64 Chevy II V8 Loaded Wagon 2004 Chevy 2500 HD Sonoma County, Northern CA |
05-22-2002, 03:31 PM | #8 |
jim pace was 115.00, i thought someone had posted an 89.00 price. i can cut bracketts off of them. i am tired of starter problems and exhaust leaks,i have 2 1/2" exhaust with a crossover and flowmasters allready am looking for ramshorns. how about good used ones.
------------------ 1972 3/4 4x4,14bolt locker rear, dana60 and locker front, nv4500, 383, blazer tank,dual batterys,4" lift,285-75-16's, daily driver other trucks 1972 1 ton dually 4x4,454 4 spd,4" lift,255-85-16, flat bed front and rear winches, rear battery and under bed gun safe.
05-22-2002, 06:50 PM | #9 |
You'll never find used 2 1/2" rams horns because they were only on corvettes. They are out their, but why chacne a warped or cracked one. I put two of the drivers side 62-63 manifolds on the Jimmy. I used my band saw to remove the gen mounts, then smoothed it over with a 9" grinder. There is a HUGE size difference when you compare the two. I replaced my Heddmans after the flanges rusted too much to seal. I love them as they seem to make as much power and they seal up awesome and are real quiet under the hood. With the Dynomax Hemi Turbos it sounds awesome at idle and WOT without ever being too loud.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
05-22-2002, 07:42 PM | #10 |
bummer that angle dump versions are not available for the 2WD crowd... I'm running straight dumps on both sides, even tho passenger side would be much better if it was angled... would make it easier to get to the exhaust flange bolts... might hafta go for em anyway, I've lived with it this long, won't be any worse off, plus it'll breathe better...
------------------ '72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA http://www.ixpres.com/vlusardi/chevtrk.htm
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
05-22-2002, 07:50 PM | #11 |
Headers are the only way in my book........gotta hear those valve springs snappin,thats all part of a performance eng! .........69
http://community.webshots.com/user/hotrodhorn |
05-22-2002, 10:37 PM | #12 |
I have a set of 21/2" straight dump ram horns with the altinater bracket cut off I would sell. They are brand new and never used. I was going to use them in my Jeep with a SB but changed my mind. E-Mail if interested. If I dont answer tomarow I will answer on Tuesday. Im going back to Florida Friday morning and will be there Sunday. Thanks Gary
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
