Old 11-19-2009, 01:08 AM   #1
82chevy350
82chevy350's Avatar
Head Gasket
Im running a 350 bored .030 over 9355)
i have 76 cc chamber heads i know im guessing anyway the heads are 920s
i wanna know what size compressed head gasket do i need to run to achieve my goal of at least a 9 to 1 ratio
Drive It Like Ya Stole It
'82 Primer White c10 2wd LWB 350 sbc t350
(Hot Rod)
'90 2wd LWB Silverado 350 tbi 700R4
(Daily Driver)
'53 m38a1 Willys Jeep
(Toy)
82chevy350 is offline   Reply With Quote
Old 11-19-2009, 11:25 AM   #2
Ticker
Re: Head Gasket
There's not really enough information there to make a recommendation. Generally on a 350 changing from an .048 to .015 gasket will give about a .6 increase in CR. You'll want one of the rubber-coated steel shim gaskets as the deck/head surface won't be smooth enough for a steel gasket.
There's no reason to chase CR unless you're doing a cam swap that needs it - a .5 increase in CR is worth maybe a 1-2% power bump on an otherwise stock or mild engine.
Ticker is offline   Reply With Quote
Old 11-19-2009, 01:12 PM   #3
82chevy350
82chevy350's Avatar
Re: Head Gasket
Well i do plan on runnung a .510 lift cam or a .460 was gonna put 305 heads on it but i would run out of top end just wanting some more torque
(Hot Rod)
(Daily Driver)
(Toy)
Old 11-19-2009, 02:22 PM   #4
Ticker
Re: Head Gasket
Increasing CR won't measurably increase torque...and 305 heads are complete junk regardless of the CR increase they give with a smaller chamber.
The best way to increase torque, given the little detail here, is to swap the cam for an "RV" cam, put on good headers, ideally a tri-y design and look at a torque coverter swap.
Old 11-19-2009, 10:41 PM   #5
shortbed70
shortbed70's Avatar
Re: Head Gasket
No 305 heads,4x4 cam GEARS,GEARS. It will make a stock motor seam very strong off the line. Ask me how I know. 4.56 26" tall tire and th 350 trans.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
