Old 11-19-2009, 08:44 PM   #1
brew8
Is this a Dana 44
Is this a Dana 44 front axle??
brew8 is offline   Reply With Quote
Old 11-19-2009, 08:54 PM   #2
LONGHAIR
Re: Is this a Dana 44
Nope.....Corporate 10 bolt. Those came after the Dana44
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-19-2009, 09:33 PM   #3
eric67m
eric67m's Avatar
They look rounder than the 44. Also the 44 will have 44- cast in the web to the bottom right of the pumpkin. i believe there is some interchange between the two from the knuckles outward. They both have their pluses and minuses, very simular.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 11-20-2009, 03:42 AM   #4
sweet70beast
sweet70beast's Avatar
8.5 inch 10 bolt
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 11-20-2009, 10:52 AM   #5
70 beast
Certified Hobbiest
70 beast's Avatar
yup. thats a 10 bolt. some people like em....some people dont.
imo it all depends on how you use it.
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 11-25-2009, 10:30 PM   #6
msgross
msgross's Avatar
correct, from the knuckles outward they are nearly identical, most parts swap. The inner axles don't though. For a 1/2 ton truck there isn't much to gain or lose between the two. Sure the spline counts on the inside are slightly different, but if you drive hard enough you could break both. Some have 3" axle tubes and some have 2.75" tubes. newer corp 10's have metric banjo bolts on the brake caliper, but both calipers will work on the axle, I think...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
