11-25-2009, 06:49 PM | #1 |
afr 345 big block heads
I can buy a set of 345 afr's for $1200 and wondering if these would be to big for my 431? My iron heads are 320 with alot of port work etc.etc. I need to let him know before tomorrow or he's going to post them up for sale...He says that they only have 40 passes on them and i can hear them run on his car before he pulls them...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
11-25-2009, 09:11 PM | #2 |
Re: afr 345 big block heads
I'd go for it. It will save you a bunch of weight. You might want to pm big Jim I think he runs afrs.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
11-26-2009, 12:23 PM | #3 |
On a budget like Fred Sanford
Friend of mine runs cnc afr 335's on his 9:1 427....thing makes a TON of torque. Get 'em!!!!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 11-26-2009 at 12:23 PM. |
11-26-2009, 12:25 PM | #4 |
Id get them just for the savings, They are a little to big but if you get a bigger stall and maby take another look at your cam you would be good. It is just going to take you longer in the RPM's to make all the power.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
11-26-2009, 02:03 PM | #5 |
Get 'em. That's a good deal. They're a bit big for your combo, but you'll have an awesome top end if you build it right - or you could always add a blower...
11-27-2009, 12:03 AM | #6 |
when I was on pass time I had a 390cfm head on a 468. If you run a little spray they would love it.
