Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-29-2009, 11:46 PM   #1
72Horn1Ton
Olds 350 DX hp
I got this long block engine when I bought my truck. Opened one head to check it out. Ross pistons Pulled the pan. 4 bolt mains I do not recall the conn rods. 455 bb K heads. I have heard this DX block is a 500 to 700 HP capacity. Anybody have any thoughts? or suggestions.
72Horn1Ton is offline   Reply With Quote
Old 11-30-2009, 12:16 AM   #2
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Olds 350 DX hp
Don't know alot about them, but have been told they are one of the more durable HP per CI Olds combos. The DX is without argument the strongest OE Olds block. I think a 440ish CI build is common with a steel 425 crank, or a small cube version with a steel 330 crank. What crank is in yours? I thought the later "K" heads were not much good for making power (big CC's). I wonder if the builder was going turbo or nitrous?
Hmm, a friend has several DX engines, I have a 330, 403, 425, 455- maybe I should...
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 11-30-2009, 12:29 AM   #3
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Olds 350 DX hp
Guess I was thinking about "J" heads. Here is what I found on the "K" heads.
Marine, irrigation, industrial, W-30/Toro, 442 4-speed replacement head. Most were big valve units.
Old 11-30-2009, 12:33 AM   #4
72Horn1Ton
Re: Olds 350 DX hp
I do not know what crank. K heads are 80cc, unless shaved.
Old 11-30-2009, 10:59 AM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Olds 350 DX hp
DX is the LF9 deisel block 81-89? i has the bigger lifter bore . I had an 80 Delta 88 5.7 smoker .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-01-2009, 07:26 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Olds 350 DX hp
Originally Posted by 72Horn1Ton View Post
I got this long block engine when I bought my truck. Opened one head to check it out. Ross pistons Pulled the pan. 4 bolt mains I do not recall the conn rods. 455 bb K heads. I have heard this DX block is a 500 to 700 HP capacity. Anybody have any thoughts? or suggestions. Attached Images
I say bolt on a good flowing set of heads . Take the intake to Ratt Daddy in Baytown , have it plumbed for a fogger , and spray it with at least 250 .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-01-2009, 08:42 PM   #7
72Horn1Ton
Re: Olds 350 DX hp
How much more flow than 455 k heads can you get?
Old 12-08-2009, 01:39 PM   #8
369stroker
Re: Olds 350 DX hp
72horn1ton shoot me an email and I can help you with this 350 DX setup.
Ebrok8@aol.com
369stroker is offline   Reply With Quote
