LS series PCM mounting
ive gotten a few questions on where/ how i mount my PCM for the LS (4.8 5.3 5.7 6.0) engines.... i use the factory truck PCM mount, cut off the backside (so im left with a box)....then i make some angles, one side 'rests' inside the factory notch on the firewall (the one im pointing to), this also locates it...then you can either weld the tabs on, or drill holes in them and bolt them to the firewall.....the PCM simply slides/snap in the holder, makeing for easy removal if neccessery...
Re: LS series PCM mounting
looks nice
I mounted mine on a sheet metal mounting plate on the inside of the firewall. |
![]() Join Date: Jul 2009
I dont know about mounting it there. Its gonna be pretty hard to get to once engine and trans are in
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
i have it mounted there in my black truck, ive had to change the computer in it before...took all of 5 mins, and 4 of which were getting the screws loose to get the PCM connectors off.
Still Learning
I guess you have to have your motor mounts set just right to have sufficient clearance to access it right? Just saying, when you mount your motor in the frame, is it possible to have it mounted too far back?
Mike |
shnnaaazzzyyy
#7 | |
![]() Join Date: Feb 2004
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
I mounted mine behind the dash between the column and the radio.
Chris. Was your harness a uncluttered stock lenght harness ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Yep......stock harness that I had Ken W. make stand alone. It was not lengthened.
![]() Join Date: Apr 2005
Passenger's side core support...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Mine is similiar to Rob's above except its on the driver's side and the harness connectors enter from below. had numerous folks ask me where I had it hidden and it was right there in front of them.
#13 |
![]() Join Date: Sep 2007
i need my harness modified as well, does he do this as a business?
1967custom |
#14 | |
http://www.standaloneharness.com/ |
#15 |
Not the best picture, but I am using the Tejas Steelworks ECM mount with a small mod to my ECM mounting (longer standoffs) due to my harness routing.
