12-19-2009, 10:47 AM | #1 |
a rotor swap question
I read most of this thread a week or so ago while searching for info on some new rims for my truck. And forgive me if this was brought up already and I missed this info.
My truck still has the drum brakes up front which has to go. I found this : http://www.ecklerstrucks.com/product...3&dept_id=1035 Would this solve the problem to get these wheels to fit, by changing the rotor to a different bolt pattern? Two days ago I purchased a whole suspension clip out of a 1980 5/8 ton truck, with plans to swap it over to over to my 68 GMC swb. I putting in a 8.1L (vortec496) with the 4t80e and thought this would be better for the extra weight I will be carrying now. So, does anyone know if a rotor from a chevelle (like in the above link) will just slide on the 5/8's spindle and give me the 4.75 bolt pattern Im wanting? The reason Im doing this mainly is that Im putting in my beefed up `10 bolt s10 rear axle to give me a tubbed look. Thanks in advance for you input on this situation..... |
12-19-2009, 11:16 AM | #2 | |
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Also.... You state you want to use a 10-bolt S10 rear housing for a tubbed look. These wheels are a great deal only if/when they fit w/o extra mods ($$) required. They come in only one back-spacing so that along w/a 4" narrower rear housing is going to put the wheels waaaay inside the wells & will give that 'too much' look. You'll need wheels w/less back-spacing so they'll set within the wheel well properly & still give that killer big lip look you want.
12-19-2009, 11:58 AM | #3 | |
I have the s10 rearend up under the truck now. Just laying on the floor under the rear end thats in the truck now. From what I measured so far these will be a perfect fit. So the fronts are what Im trying to figure out now, I need to redo everything on the front suspension on the truck now. I just got the 5/8's ton suspension a couple days ago. I really want to just rebuild all the 5/8's tons suspension on it and put it on the '68. The problem is I dont know if I can slide on a rotor from a chevelle, if so I will for sure get a larger drilled rotor upgrade. Just though I would pick someones brain on this. I guess I will run down to Autozone and buy a cheap rotor and some bearings and see if it will work. Thanks for your responce! |
12-19-2009, 12:34 PM | #4 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-19-2009 at 12:34 PM. |
12-19-2009, 12:52 PM | #5 |
Thanks!!!! Back to the drawing board...... Also do you have any idea if there is a rotor that I can use to swap, maybe like a caprice with hd brakes? Im just reaching here.....
12-19-2009, 01:01 PM | #6 |
what is a 5/8's ton truck?
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
12-19-2009, 01:20 PM | #7 |
[QUOTE=djracer;3682823]what is a 5/8's ton truck?[/QUOTE
Its a HD model between the 1/2 ton and the 3/4 ton trucks. Supposed to have heavy duty brakes, swaybar, ect. I got the whole suspension still mounted on a frame thats cut about three feet back down the frame for $100.00. |
12-19-2009, 01:38 PM | #8 |
67-72 parts collector,…
POL (PerformanceOnLine.com) has a rotor that will bolt on your 80's truck suspension and has the 5x4.75 bolt pattern.
http://www.performanceonline.com/sto...at=1086&page=1
12-19-2009, 04:42 PM | #9 |
Re: a rotor swap question
Thanks for the move, Im really sorry I dont know what I was thinking..... I get the wheels turning upstairs and forget that I was is someone else thread... Sorry again....
In short what I need to know is does someone make a disc rotor form a 1980 Chevy 5/8 ton that has the bolt pattern of 5x4.75? Thanks in adavance |
12-19-2009, 05:07 PM | #10 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-19-2009 at 05:08 PM. |
12-19-2009, 05:59 PM | #11 | |
YES. http://www.performanceonline.com/sto...at=1086&page=1 Ask question,... read answer,...
12-19-2009, 07:15 PM | #12 | |
12-19-2009, 07:26 PM | #13 |
The fact that POL sells a rotor with a 5x4.75 bolt circle only starts the problems.
Most wheels that have the 5x4.75 bc don't have a big enough center hub opening. These are Chevy passenger car wheels. Keep us posted on your progress. I don't know of anyone running these rotors, and I'd like to see how they work on our old trucks front suspension.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-19-2009 at 10:43 PM. |
12-19-2009, 08:24 PM | #14 |
Happy to be here
I pulled your thread from the original post since it had a life of it's own. Your good to go now...
