Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-21-2009, 02:39 PM   #1
JET4x4
Rear end swap question
My question is will the rear from an 88 s10 4x4 blazer bolt into a 95 s10 4x4 pickup, assuming they have the same gear ratio?
67 Chevy K20 LWB Fleetside project
85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project
86 m1009 blazer, 6 in lift, 35's, driver
69 c10, 307, long bed, 3 speed, driver
07 Dodge 2500, cc, lb, cummins turbo diesel
00 z28 camaro, ls1, 6 speed, rarely leaves the garage
JET4x4 is offline   Reply With Quote
Old 12-23-2009, 10:48 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: Rear end swap question
I happen to have a 94 S10 4x4 pick-up at work I can measure. spring width, spring spacing, spring length, I can try to get drum to drum as well. this is of course assuming I remember to do this.
68C15 is offline   Reply With Quote
Old 12-24-2009, 10:02 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
spring center to spring center = 38.5"
backing plate to backing plate = 52"
spring width = 2.5"
both shocks mounted to the rear of axle on a plate under the springs
springs above axle
I don't know if I need to measure from pinion to each spring or not.
Old 12-30-2009, 04:08 PM   #4
Myself
Yes it will work. The mounting dimensions are the same.
Myself is offline   Reply With Quote
