Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-10-2010, 06:17 PM   #1
EyeH8the24
EyeH8the24's Avatar
s-10 heater problems
my daughters 97 s-10 has a heater problem...it only blows cold air ...it has a new thermostat and the engine heats up to around 195 to 200..but it only blows cold air ..any suggestions ?
DOH !!!!!!!
EyeH8the24 is offline   Reply With Quote
Old 01-10-2010, 08:36 PM   #2
stan79chevy
stan79chevy's Avatar
Re: s-10 heater problems
un hook the heater hoses. Put garden hose on one side and purge out all the crap in the heater core. Then do the same to the radiator then the engine block and fill it up with the green stuff. That orange fluid is good until it gets slightly old then it turns into some kind of mud..aslo if you mix it with the green it turns into mud.
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 01-10-2010, 11:22 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
the heater cores being so high in the system combined with Dexcool and a system that has even the smallest amount of air in it will plug up a heater core. the dexcool sludges when exposed to air.
flush the whole system and go with green.
68C15 is offline   Reply With Quote
Old 01-11-2010, 07:26 PM   #4
EyeH8the24
EyeH8the24's Avatar
thanks ..i have already flushed everything but the heater core...im gonna do that this weekend .....i have been running the green stuff for last two years ...the dexcool stuff sucks ..it totally clogged the old radiator ...thanks again ill let you guys know how this works out
DOH !!!!!!!
Old 01-13-2010, 01:19 PM   #5
a55togo
a55togo's Avatar
check the heater control valve to be sure it is opening.
Ed
a55togo is offline   Reply With Quote
Old 01-13-2010, 11:09 PM   #6
68C15
blood type; Retumbo
68C15's Avatar
Ed
these don't have one. temperature is regulated with a door driven with a feedback actuator.
