Old 01-14-2010, 01:12 AM   #1
Phlebmaster
Phlebmaster's Avatar
Talking Phlebmaster's 1972 C20 Evolution***56k- NO WAY!
Hello,
My name is Aaron, I am new to this forum, I have a 1972 Chevy C20 I picked up after selling my Datsun 240z project. I have been updating my C20 project thread on the Datsun enthusiast sites (you can google my username if you are curious) and thought I should post this up here. Be aware that this post will be long and full of pics to get you up to speed on my project. Thanks for your time. Aaron
Please forgive the multiple posts.
Here we go........11/17/09
Well, I did what I said and picked up an older Chevy truck after I sold my 240z. I just got it home this morning.
I now have a 1972 Chevy C20 3/4 ton Camper Special. I paid $600.00 for this beast. She needs a few things but there is very little in the way of rust and I just happen to have an extra 350 sbc to throw in once it is re done.
I have not had time to look every little thing over...but the truck has a 350 and I am not sure if it has the TH350 or TH400 since it is a 3/4 ton. But it runs good, sounds good, and shifts nice.
Ok...here are the pics.
I can tow stuff now.
Not the prettiest example of a classic Chevy truck...but very functional and workable.
I picked this up! Edelbrock Performer intake.
Phlebmaster is offline   Reply With Quote
Old 01-14-2010, 01:14 AM   #2
Phlebmaster
update 11/25/09
Here is how the engine looks now....kinda ugly. I will take pictures of the "after" I make my changes so you have a comparison.
Before...
This is what is going on the 350.
This is a Comp Cams 270H with a 112 LSA and 4/7 swap. I can't wait to get this in.
Old 01-14-2010, 01:17 AM   #3
Phlebmaster
update 12/03/09
Well, after much research and discussion with those who know about what I plan on doing with my engine I have decided to do this one step at a time rather than all at once.
Tonight I put my new intake and Holley 750 on. I will install my cam once I get heavier springs. I can tell you this about the stock crap that was on my truck...the intake had a bunch of loose bolts and all of the fittings were not tight either. It is a wonder it even ran! I fixed that though.
I will not be able to test this new stuff out until I get a new water fitting that runs from the intake to the heater core.
Here are the obligatory pics of the swap!
So it begins,,,,
Now that feels better already! Damn that thing is heavy!!
All finished for tonight...I can't wait to start her up tomorrow!
Old 01-14-2010, 01:19 AM   #4
Phlebmaster
update 12/10/09
I started to tear apart my motor tonight so I can put my new heads on and make sure my cylinder walls are ok.
I have dished pistons so I can get away with the small chamber heads I am going to use.
A little paint for show....
The 624 heads that were on my truck are the 1.72 valve!! I am glad to not have to use them any more. Now I have a set of 1.84 1.50 valve 58cc heads. You can compare the old head on top with the 58cc head below.
Old 01-14-2010, 01:20 AM   #5
Phlebmaster
update 12/16/09
Progress tonight!
I put on the new heads and got them bolted down. I followed the correct torque sequence and procedure for getting them done right.
Feels good to make some progress! Now I just need the friggin carb that works. lol
Old 01-14-2010, 01:23 AM   #6
Phlebmaster
update 12/18/09
I made more progress tonight....
I got me a new Edelbrock 1404 500 CFM carb tonight that is actually NEW!! Thanks to Blackice280z and kamakazi620. I also have a good Q-jet coming tomorrow....so I will have two q-jets (one good & one worn out) and one new 1404 carb at my disposal. I am very happy about that.
Funny thing...it says Weber on it! lol
Old 01-14-2010, 01:24 AM   #7
Phlebmaster
update 12/25/09
I got her running tonight!! YAY! I will have a video tomorrow including before and after shots.
Update 12/26/09
Here is the video.
enjoy!
Old 01-14-2010, 01:25 AM   #8
Phlebmaster
update 1/08/10
I picked up my headers tonight. Maybe a swap this weekend?? I don't have the flange/reducer portion that goes from the headers to the main exhausts, or the heavy gasket, or the locking header bolt/nuts. But those are not that expensive.
Old 01-14-2010, 01:27 AM   #9
Phlebmaster
update 12/11/10
I got bored this weekend so I decided to swap in my cam. The cam is a Comp Cams Magnum series 270H 112LSA with the 4/7 swap. This was actually easier than I thought it would be. I have no coil bind or issues with my rocker travel. The springs are new springs so will work with this cam until I can get my vortecs.
Here are the pics.
This picture was a big help!
I was happy to see this under the timing cover.
Here is the old lifter...it looks like someone has replaced them along with the cam because the cam looks to be in great shape and these are definitely Comp Cams lifters.
Here is the new cam all lubed up and ready to slip in.
Here is the old timing set, I am looking for a gear drive set up.
It was late so I was not going to rev the motor at 2000 rpm for 20 minutes...I will do this later today. Video to follow of course!
update 1/12/10
Here is the promised video.
This was my first time swaping a sbc cam. I left the 081 heads stock on my 350, but put new extreme push rods, 270h cam, and lifters. So, you can run a .470 lift cam on stock heads,(WOULDN'T RECOMMEND IT...but I did it). I spent many weeks looking for that answer ans now I have the experience for my self. I also could not find a good sound clip of this special grind cam online- so now there is one....enjoy!
Just so you know, I am running 305 (081) heads on my 350 and I am very happy with the results. I read way too many posts on way too many forums saying yes...no...yes..no....and I was like what the hell?? So I did this for my own knowledge and experience.
So, let's sum this up:
First Myth: you can't run 305 heads on a 350......
Can you run 305 heads on your 350? = YES! And you can get a decent flow with the right heads, stay away from the swirl port heads. Use the 081 non-swirl type. I would have prefered to used some 350 after market heads or maybe even vortecs....but I had these heads so I used them. 350 heads will out flow and out perform any 305 heads anyday, but if that is what you got...them use them.
Be carefull about your compression ratio, I have stock 12.5cc- 4 valve relief dished pistons and with 58cc 305 heads I am at about 9.74:1 to 10.00:1 compression so I will be running premium fuel. Flat top pistons will make your compression ratio bump beyond that and you may be buying expensive gas to drive your rig....so look out for that.
Next myth: max lift for stock heads is .450 or ?????.....
Can you run a .470 lift cam on stock heads?? = YES! but you must make sure you look for coil binding and clearance between the spring retainer and valve guide before you run the motor. DO NOT REV your motor the moon!! Stock springs especially worn ones will not handle the ramping at all, and you will have valve float. I recommend using the recommended set-up by your cam manufacturer.
I went through many weeks of looking for a simple answer online and never found a strait answer. I hope this information helps the next person who reads this post.
Old 01-14-2010, 01:31 AM   #10
Phlebmaster
Re: Phlebmaster's 1972 C20 Evolution***56k- NO WAY!
Now you are current and up to date. I will post more as I do more. Thanks! Aaron
Thanks, Aaron
Life is about making dreams come true, stop dreaming and make life happen.
64 GMC Project MY_YOUTUBE_VIDEOS To keep an opened mind- speculation is devine.
Assumptions always lead to a dead end!
Old 01-19-2010, 01:29 AM   #11
Phlebmaster
I am picking up a dual exhaust on Wednesday with a set of cherry bombs. It should sound pretty loud!! Pics soon. I am trading a 400 crank and pressure plate for the exhaust system.
Oh..and video of before and after too. lol
Thanks, Aaron
Old 01-19-2010, 10:06 AM   #12
bigguy69
dazed and confused
bigguy69's Avatar
looking forward to the video!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 01-19-2010, 07:11 PM   #13
Phlebmaster
Just in case anyone was curious about how I acquired my Chevy project...I posted my previous projects here: Projects from Phlebmaster's past
Lots of good info there about me and my journey before I got my truck. Enjoy!
Thanks, Aaron
Old 01-20-2010, 01:34 AM   #14
dccarpenter
Thanks for posting these, those pics were awesome. It was great to see the process photographed for those of who may be doing the same thing at some point soon.
Hope you continue documenting the rest of the work on your truck.
dccarpenter is offline   Reply With Quote
Old 01-20-2010, 12:32 PM   #15
Phlebmaster
Thank you
I like to document my projects just for the reason that it may assist someone else like me who is researching/planning something they have never done before. Pictures always speak louder than words for me, and I like to make videos/slide shows of everything anyway...lol
Stay tuned, because there will be more to come thanks to the help I am getting from this forum!
Thanks, Aaron
Old 01-21-2010, 12:50 AM   #16
Phlebmaster
I am ready to swap in the headers and so here is the "before" sound clip. I am running the stock rams horn manifolds with a Y pipe and 2 1/4" single exhaust. I will post up the "after" sound clip as soon as I get it done.
Thanks, Aaron
Old 01-22-2010, 12:56 PM   #17
Phlebmaster
Smile Re: Phlebmaster's 1972 C20 Evolution***56k- NO WAY!
I just purchased this for my truck!! My truck will have that noisy whine and my timing will be exact. This set also comes with the adjustable timing inserts. This will get installed as soon as I can get the time to put it in....video time! lol
Thanks, Aaron
Old 01-24-2010, 08:49 PM   #18
Phlebmaster
Talking Re: Phlebmaster's 1972 C20 Evolution***56k- NO WAY!
Updates!!
I picked up my gear drive today and installed my headers. I also have another goody for my truck...an Accel HEI dizzy.
Here are my MR Gasket headers installed and waiting for gaskets and header bolts. I can't wait for my next video!!
Thanks, Aaron
Old 01-28-2010, 12:04 AM   #19
Phlebmaster
Getting ready to pull my 350 and rebuild the bottom end. I test fitted my headers to make sure of my clearance and they fit nicely with very few mods.
My gear drive is soaking in heavy oil pending install when I pull the motor. I will make sure to document to the entire rebuild including the cam gear drive in order to hopefully help the next guy out.
First thing I will do is make a video of my header exhaust sounds with the cam prior to running that noisy cam gear, then an after video is in order.
I have learned a lot here since joining...thank you for being here!
Thanks, Aaron
Old 02-01-2010, 12:41 AM   #20
Phlebmaster
I put the cam gear in today.
Video as promised.
Thanks, Aaron
Old 02-06-2010, 11:16 AM   #21
Phlebmaster
I am putting the HEI on this weekend. Anything I should look out for??
Thanks, Aaron
Old 02-06-2010, 12:21 PM   #22
marcsRX
68 C10 SWB
marcsRX's Avatar
Great progress buddy!
Make sure you get cyl #1 to TDC to install the dizzy.
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman
marcsRX is offline   Reply With Quote
Old 02-12-2010, 12:00 AM   #23
Phlebmaster
Ok, after noticing that I may have a cracked block in the lifter valley I did some research on how to repair it or what to do. The consensus was to replace the block.
I just picked up a short block with a code of: T0823CRX and casting of: 3970014, 2 bolt main. The block is dirty, but not all rusted out like the picture seem to make it look. There is also no ridge on the cylinder walls!! It was stored in a temp controlled shop. My camera sucks and it was raining tonight.
With a date matched set of heads date code: C 19 4 and casting: 8795896.
60 CC 1.72 intake 1.50 exhaust
Now I will just rebuild the short block and swap it into the truck, then figure out what can or cannot be done with my high nickel short block after I pull it.
Here are the pictures of my goodies......
I noticed the pistons are weird looking...they have a stamped notch or hole in them??
Thanks, Aaron
Old 02-12-2010, 12:21 AM   #24
VA72C10
VA72C10
VA72C10's Avatar
sorry bout the other block but glad you found another reasonably priced...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-12-2010, 12:23 AM   #25
Phlebmaster
I don't think I mentioned the price...but yes it was reasonable. I got all of this for $30.00 from a guy who just wanted it gone. lol I was blessed for sure!
Thanks, Aaron
.470, 305, 350, heads, max lift
