Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-16-2010, 09:30 PM   #1
TLoz
Engine light on @ idle
Hi everyone,
My son has a 1993 S-10. The engine light comes on whenever he puts it in park and lets it idle. If you put it back in gear, the light goes off. He took it to Advance Auto to have the codes checked, but it was to old for their equipment. Anybody seen this before? Thanks, Tom
TLoz is offline   Reply With Quote
Old 01-16-2010, 11:18 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: Engine light on @ idle
"too old for their equipment"?! they don't have a $2 code key?!
jumper pins A and B, turn key on, and watch the light flash the codes.
flash...flash-flash (3 times = code 12, OK now it's time for the problem codes)...longer pause, then (example) flash-flash-flash-flash...flash-flash-flash-flash-flash 3 times (example) means code 45 (rich exhaust IIRC)
it will cycle through the codes in numerical sequence with a long pause in between and then go back to a 12 signifying the cycle is complete.
68C15 is offline   Reply With Quote
Old 01-18-2010, 01:40 PM   #3
ChevyTech
Here are some web sites with the basics on retrieving codes from the ECM without a scan tool or code reader.
Poor drawing of ALDL/DLC but ok instruction + codes
http://www.cfm-tech.com/gm_tbi_trouble_codes.htm
OBD1 terminal identification
http://robertpowersmotorsports.frees.../ALDL_plug.jpg
OBD1 illustration and instructions
http://www.troublecodes.net/GM/
