Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-17-2010, 07:34 PM   #1
james colbert
weight
Any of you guys scale your trucks? I found out my truck is a pig sat on the scales. What do you guys weigh?
james colbert is offline   Reply With Quote
Old 01-17-2010, 07:36 PM   #2
1971gmcshortbed
1971gmcshortbed's Avatar
Re: weight
I am curious of answers here, i'm nowhere near putting mine on a scale but I would like to know what a 67-72 shortbed 2wd weighs. I'm thinking 3200 to 3400 lbs but I may be off.
1971gmcshortbed is offline   Reply With Quote
Old 01-17-2010, 07:49 PM   #3
james colbert
Re: weight
Im 230, with 2 full NOS bottles and a full tank of gas I was at 3965. With 43.6 on the rear. I have a 57 cab and bed but it cant be that much more that yours
Old 01-17-2010, 10:42 PM   #4
Wild83C10
Wild83C10's Avatar
Re: weight
I was at 3703 lbs (as measured with aircraft scales at all 4 corners), but after I am done this winter I should be down to around 3550, hopefully.
sbc, 10 gal of fuel in a 20 gal aluminum fuel cell.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 01-17-2010, 11:21 PM   #5
69trk
69trk's Avatar
Re: weight
mine weighed 3950 before the glass hood and removing a few other things.. I'm thinking it might weigh 3800 or so now...I'll weigh mine again this spring
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 01-18-2010, 09:45 AM   #6
Alex1
Alex1's Avatar
Re: weight
1980 Chev Stepside: 3800 lbs. All iron big block, 1/2 tank of fuel, TH400 and a dry rot wood bed. Weighed it last summer.
Alex1 is offline   Reply With Quote
Old 01-18-2010, 10:33 AM   #7
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: weight
3950 lbs
1969 LWB Fleet, 5.3/4L60E (at the time, 4L80E now) half tank of fuel, no driver, full interior, air bags on all 4 corners.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-18-2010, 07:45 PM   #8
Super73
Super73's Avatar
Re: weight
Last time on the scale it was 3,620, full tank of gas 16 gallons, me in it (200lbs) and about 100lbs added to the tailgate. I redid the exhaust recently and probably down another 20-30lbs.. Truck is 51% front and 49% rear. Keep in mind though I have done a lot to get the weight down and run and alum block/heads, no hood, no inner fenders. However, the 4L80E I have in it is flipping heavy.. Shipping weight with a factory verter with no fluids on a pallet was 270lbs..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-18-2010, 07:52 PM   #9
james colbert
Re: weight
Glad to see Im not to far out, I wasnt thinking it was as heavy as it is
Old 01-18-2010, 09:40 PM   #10
team39763
Re: weight
That's pretty light. I've gone retarded with the weight reduction and most people estimate I'm still at 3650. I'm looking at doing ladder bars in the rear(to replace my leafsprings) and an aluminum block to lighten the front. I was going to get an aluminum driveshaft, but I was told that with the length I needed, I'd need to run a large aluminum shaft which may defeat most of the weight savings over a smaller steel one.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 01-18-2010, 10:22 PM   #11
Super73
Super73's Avatar
Re: weight
It's pretty light for a truck for sure.. DJ still has me beat though with his big block and cage to boot. There is a bit more weight for me when my wallet allows..
I still need to:
Mount the fiberglass front I have (guessing it's another 30-40lbs out)
Build a new frame
Do a Mustang 2 style front suspension with rack and pinion
Switch to a glide
I could see with the above getting another 200-300 out of it.
Old 01-18-2010, 11:09 PM   #12
Marv D
Registered Truck Offender
Marv D's Avatar
Re: weight
Wow, guess mine is a lightweight, my backhalved 66 with street grade USbody source front fenders and hood, 3385 pounds with 6 gallons of fuel, plus my pfhatass @ 195 for 3580 sitting in the beams.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-18-2010, 11:18 PM   #13
Super73
Super73's Avatar
Re: weight
Marv, our trucks are now very close in weight.. What did you say back halfing shaved again? 2x3 or 2x4 box and what wall thickness? If memory serves you did a ladder bar as well right?
Old 01-19-2010, 12:26 PM   #14
Marv D
Marv D's Avatar
Re: weight
Mines the Alston urathane bushed street 4link package. Prebent 2x3 framerails with Alstons NHRA+ wall thickness (pretty sure it was .130" wall). Really don't know what I saved weight wise,, loosing the frame rails, the wood bed, the truck 12bolt, stock steel wheel tubs, with trailing arm suspension ... and replacing with the light weight frame rails, narrowed 9" with light disks, coil-over suspension,, sheeeeze. Probably 300-400 pounds +. The bedsides are original steel, but everything else from the cab back was whacked, replaced with aluminum, or plain ol deleted.
Old 01-19-2010, 09:18 PM   #15
fast_dev
fast_dev's Avatar
Re: weight
mine is pretty light, 3475 with me in it according to the scale at my local nhra track. 3300 without me. its an iron headed small block with a four speed. its all steel, just missing some stuff. no inners, rad support is lightened, plastic race seats, lexan side windows with no regulators, still have the wing windows and others are still glass. no heater or any other stuff not needed, no tailgate or back bumper.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 01-20-2010, 12:33 PM   #16
team39763
Re: weight
I still need to:
Build a new frame
Switch to a glide
I don't mean to take this too far off topic, but aren't our trucks too heavy for a glide? From what I've been reading, they say you need a light car(3000lbs or less) or lots of power to take advantage of a glide.
Old 01-20-2010, 05:29 PM   #17
Super73
Super73's Avatar
Re: weight
There are quite a few guys on dragstuff with big body cars running glides. The issue with them is the very soft 1st gear. But if you run the right converter, they can be effective, but t really depends on your combo. Since my motor is sorta soft on TQ NA, it would not be the best choice, but, since i plan on spraying a decent shot of N20, it could be very effective with the huge increase in TQ.
I'd say in short, for a heavy vehicle TQ helps a lot, but that's with most all tranny's..
