01-19-2010, 06:50 PM | #1 |
what headers for ls swap?
What headers are you guys running with an LS swap in the 67-72 K series?
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
01-19-2010, 08:55 PM | #2 |
Re: what headers for ls swap?
not many guys have done this as far as I know.. lots of 2WD guys have...
sorry for the lack of info
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-21-2010, 01:24 AM | #3 |
When I first did my swap, I used Hedman block hugger headers. I then switched to a set of Pacesetter LT's for a 99-06' truck. Those required notching the frame and modifying the collector to clear the shackles. Right now I have a set of Doug Thorley LS swap headers on order. I'm hoping they will fit, even with the frame filled back in. I asked everywhere, including Thorley themselves, and no one knows for sure if they work on a 4X. Doug Thorley did tell me though that to the best of their knowledge, they will.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
01-23-2010, 08:23 PM | #4 | |
charlie
01-24-2010, 07:54 AM | #5 |
I would be afraid to think how to make some fit. I don't see how you could do the swap without a suspension lift. I have an 8" suspension lift on my truck, and the oil pan is only about 8-10" away from the front differential with motor slightly tilted to the back and the transfer case raised 2" off the crossmember.
Lynn |
01-25-2010, 08:28 PM | #6 |
racin69z- What are you afraid wouldn't fit? The headers? Where do you think there would be a clearance issue?
01-25-2010, 08:56 PM | #7 |
oil pan, crossmember with the front differential.
I am trying to do it without a lift now!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
01-26-2010, 11:02 AM | #8 |
When I put mine in, I had my transfer case in the stock position and the stock engine crossmember in. I ran into oil pan clearance issues with the stock engine crossmember. I wound up building a new engine crossmember. I wound up raising the transfer case up 2" to level the motor. I could not have done it without the body lift.
As far as headers, I never really looked because mine go up above the frame. I did measure and the LS motor is about 2" wider than a standard small block. Lynn |
01-26-2010, 02:23 PM | #9 |
Anybody else?
