Old 01-20-2010, 06:27 PM   #1
chevy2311
Question 350 bored .040 over Need ideas!
K so about a year ago I bout this 71 chevy c10 and the guy gave me a 350 for free no cracks or anything just wanted to get rid of it. Well now I need to do something with it tired if it just sitting on a stand. What can I do with the engine? It's a 350 40 over the bearings I believe have been taken out to 10 over and everything else is stock. Oh btw it's a 2 bolt main. I really just want to put it in my 71 and I want to get as much out of it as I can. I'd prefer not to use nos. And I am on a small budget (married) but either way I will get the parts I need one by one. Thanks for all the help guys if you need more info just tell me I'm at work right now but when I get home I'll look at the head numbers. The block is 3970014. Everything else will have to wait for tonight.
chevy2311 is offline   Reply With Quote
Old 01-20-2010, 06:34 PM   #2
AusMarty
Re: 350 bored .040 over Need ideas!
If the bore is fine I would use it, the engine in my truck is 040 over, The bore was perfect so it got a hone and re ring, if you have to bore it, I would consider another block
AusMarty is offline   Reply With Quote
Old 01-20-2010, 08:35 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
x2, I've heard if you go .060 over then they run hot. If the bore is good then get a rebuild kit from summit or wherever and throw a cam, intake, and 650 cfm carb on it. Check out the heads to see if they are a decent casting, if they are get them rebuilt. The guy who built mine did all this and charged me $900. He guessed it is putting out about 300 HP. Too bad when it was sitting it got water in it and I had to rebuild it again!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-22-2010, 12:37 AM   #4
77chris03
77chris03's Avatar
Here's a small list what I got in mine. Nothing big.
I built mine with under 3000 bucks. Only labor was 750 ish for machine work.
I got what I could afford.
Block is 1970 4 bolt 350.
.040 on cylinders, .010 on all bearings.
Clevite bearings
speed pro flat top 4 valve relief pistons and rings
speed pro hyd lifters, crane cam pushrods
all new gaskets and seals
pro comp 1.6 alum roller rockers
melling oil pump
z28 springs
440/460 cam
cloyes double roller timing chain
head job w new valves and locks
edelbrock performer intake powdercoated
holley 600 cfm carb
pro comp high flow water pump
billet 65000 v distributor
all billet pulleys and stainless hardware
edelbrock elite valve covers
80gph holley fuel pump and stainless line
few more things just can't remember the rest
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 01-22-2010, 01:07 AM   #5
vectorit
What?
vectorit's Avatar
I'd turn it into a 327
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 01-22-2010, 02:45 AM   #6
tim21391
tim21391's Avatar
get a 400 small block crank and drop in that bad boy and some new rods and shallower pistons and make a stroker motor!!
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 01-22-2010, 08:14 PM   #7
chevy2311
Hey thanks for all the help Chris I really appreciate the advice. I was wanting to know what you think about the vortec heads. Right now i have the original 333882's and was wantingto know if they would be ok with the z28's you have suggested. Thanks for all the help everyone
Old 01-22-2010, 08:36 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
mortec.com
to see what your heads are...
vortecs heads ya goota run diff. intake im pretty sure.
John
1999 Toyota Tacoma 4x4
.040, 350, horsepower, ideas, sbc
