01-26-2010, 09:28 AM | #1 |
What oil Brand do you use?
I know this has most likely been posted before. But I would like to know whats the favorite oil. I have a 05 Tahoe and bought it about two months ago it has 30K on it and about ready for a oil change. I normally use Havoline oil but would like peoples input and suggestions. I want a good oil that will not break down. Also what filters are good. I used FRAM for a long time but I understand these have gotten cheap in construction.
Thanks for helping me out on the dumb question.
2013 Chevy Silverado, Z71, 5.3L, 4 door 2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40 Support the Troops. Last edited by remist17; 01-26-2010 at 12:23 PM. |
01-26-2010, 09:51 AM | #2 |
Re: What oil Brand do oyu use?
I used Castrol synthetic for about 20 years then, I tried royal purple and love the stuff. I seen an increase in mileage when I switch. I also prefer royal purple or K & N filters. Yes there a little more expensive but i believe there worth it.
The more I learn, the more I find out I don't know. 69 Chevy SWB w/67 front end 4 wheel discs 468 BB 700R4 Bagged Coming around slowly |
01-26-2010, 10:41 AM | #3 |
This question will bring up a slew of arguments and opinions. On that note here is mine.
I use Valvoline Max Life in my 03. I use the Mobil 1 synthetic in the TBSS. I will run regular Valvoline in the 84. I run Wix oil filters in all of them. |
01-26-2010, 10:54 AM | #4 |
Mobil 1 in my 5.3 with a Delco filter.
Delo 400 15w40 in everything else, Not that LE crap they sell now, I got some old stock. |
01-26-2010, 12:29 PM | #5 |
I have heard some good things about Mobil 1. I uesed Valvoline when I had a Cummins.
Im not trying to stir up trouble, but I have cracked open to many engines and see failures over oil grades. I plan on changing the oil between 3 and 5K. Can I switch to Syn Oil assuming the oil in it now is regular? I hope to have this Tahoe for many years. I have limited areas to purchase the products, NAPA, Advance Auto and I guess internet if theres a good place to order from.
2013 Chevy Silverado, Z71, 5.3L, 4 door 2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40 Support the Troops. |
01-26-2010, 06:54 PM | #6 |
I've got an '02 silverado with the 5.3l engine and over 110,000 miles. I've used castrol syntec, mobile 1 and now use Royal Purple always with a K&N oil filter. The truck runs great and I have never had to have any engine repairs(knock on wood lol). Royal Purple and the K&N filters work great for me! Just my 2 cents
"Only two defining forces have ever offered to die for you: 1. Jesus Christ. 2. The American Soldier, One died for your soul, the other for your Freedom. " In the Garage: '02 Silverado Ext. Cab Z71 5.3l '70 C20 Longstep 402BB |
01-26-2010, 09:21 PM | #7 | |
01-27-2010, 08:55 AM | #8 |
seems alot use Mobil one and Royal Purple. Ill have to see about getting some. Thanks again!
01-27-2010, 08:54 PM | #9 |
Mobil 1 on my truck
Valvoline Max LIfe in wife's car Wix filters
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
01-28-2010, 09:16 AM | #10 |
were do you get wix filters.
Whats everyones opinion on Puralator filters?
01-28-2010, 10:25 PM | #11 |
i run puralator filters at work never had any problems. napa auto parts sells wixs filters.
as to oil i use gastrol gtx in my personal vehicles. i put Mobil 1 in a lot of these trucks at work
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-28-2010, 10:29 PM | #12 |
Any name brand oil is good. Synthetic is not necessary unless you leave it in for a long time or the cap reads to use it. Use oem filters. GM has bulletins on engine failure from non oem filters. They are worth the extra $2. Just my $.02.
01-28-2010, 11:48 PM | #13 |
Chevy Lover Till The End.
Well, I'll tell ya, I have worked on a many of engine's in my 20 plus years of being a mechanic. I will use nothing but MOBIL 1 and WIX filters changed every 3000 miles or so depending on my driving conditions. If you keep a close eye on your oil for breakdown and keep it changed then you should have a long running, happy engine. Routine maint. is the key & using a good quality filter. JMO
01-29-2010, 09:59 PM | #14 |
NAPA sells Wix filters like stated before, but they do say NAPA on them. You can also get Wix filters at Oreilly Auto Parts. I will also use a Delco if the Wix isn't available.
01-30-2010, 01:23 PM | #15 |
I use Mobil 1 and wix filter on my 04 silverado 2500 w/6.0. I have around 100K
on it with no issues. |
02-01-2010, 09:20 AM | #16 |
Thanks all. I will check out the NAPA and compare to OEM prices. I appreciate alls help on this silly question !
02-01-2010, 11:15 AM | #17 | |
By the way, using Wix and Mobil 1 on my GM crate motor, I have been doing about 5,000 mile oil change intervals and premium fuel. The oil comes out still translucent with only a slightly darkened color. It shows very minimal breakdown after 5k!
2007 Sierra Denali 1995 Sierra 4x4 (426,000 miles and counting) 2002 Acura TL-S (how did THAT get here????) |
02-01-2010, 04:51 PM | #18 |
Amsoil and either Wix filter or AC Delco filter.
Whatever u use change it as often as possible |
02-03-2010, 01:09 PM | #19 |
great thanks.. Whats opinion on havolin oil?
02-04-2010, 10:36 PM | #20 |
Mobil 1 and Delco filters on Silverado and Grand Prix GTP
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
02-04-2010, 10:40 PM | #21 |
I have been thinking about trying Amsoil. One of my friends' dad is a dealer and would get it for me at cost. How many miles are you going between oil changes? Filter changes?
02-04-2010, 10:53 PM | #22 |
It all depends on how u use your truck. My dad and I use our truck for mics. errands- HomeDepot, firewood, picking up wine grapes, etc. So we put on about 2,000 miles a year. I change the oil and filter once a year.
02-06-2010, 12:06 AM | #23 |
Delo 400 15w40 in my Duramax
Brandon 2007 Chevrolet Silverado Classic 2500HD CCSB Duramax/Allison - 62K, Graystone Metallic - 6 inch Fabtech Lift, 5 inch Skyjacker rear leafs - 35x12.5 Toyo MT on 18"x9.5" AR Mojaves 1997 Chevrolet S10 ECSB 4.3/4L60E - 128k, Silver Metallic w/ Dark Charcoal Metallic Stripes - Bagged, Custom Paint, Large Stereo, Custom Bed, Etc... 1967 Chevrolet C10 RCLB 327/TH400 - 82k, White - A rainy day project to finish... when there's time |
