Old 01-31-2010, 06:26 PM   #1
rsavage
rsavage's Avatar
Rear Axle Codes
Does anyone have the info to decode the axle codes that are stamped on the top of the left hand tube of the rear end for all years (67-72) including Burbs? I found some info but it only included 67 and 68-nothing for my 1970 trucks.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-31-2010, 08:39 PM   #2
john
member #16
john's Avatar
Re: Rear Axle Codes
Post the numbers. someone will decode them.
john is offline   Reply With Quote
Old 01-31-2010, 10:46 PM   #3
rsavage
rsavage's Avatar
Re: Rear Axle Codes
The code on the tube is TDE. I searched the web some more tonight and found an answer to someone's question on that rear axle code on a build sheet and the answer was a 3.07 gear. Don't know for sure if that is correct. Truck had a 307 with a 4 speed.
1961 C1 Corvette
2021 Durango RT 5.7
Old 02-01-2010, 02:40 PM   #4
john
member #16
john's Avatar
Re: Rear Axle Codes
You are correct. 3.07:1 for code TDE if the gears haven't been changed.
Old 10-28-2012, 05:12 PM   #5
1955 mancave
1955 mancave's Avatar
Re: Rear Axle Codes
help please.
how about g
BXG0141
1955 mancave is offline   Reply With Quote
Old 10-28-2012, 05:59 PM   #6
SS Tim
SS Tim's Avatar
Re: Rear Axle Codes
If you are going to do any real detective work a parts manual is a good reference to have. Axle and engine codes are only a small fraction of the useable data. Now since I have posted links several times to a parts catalog and the GM parts Wiki I'm going to make you work just a bit. So go to the link and read, if you must shortcut down to post #17. Remember parts manuals are like a new language if you have not been exposed to them before.
http://67-72chevytrucks.com/vboard/s...16#post5668516
http://www.gmpartswiki.com/browse
Last edited by SS Tim; 10-28-2012 at 06:06 PM. Reason: Never let a dog type! Too many typos!
SS Tim is offline   Reply With Quote
Old 04-09-2013, 06:05 PM   #7
rt65s
Re: Rear Axle Codes
I have 12 bolt rear end with this code stamped on the right tube:
HE121W
Any info. would be great, thanks
rt65s is offline   Reply With Quote
Old 04-09-2013, 06:29 PM   #8
john
member #16
john's Avatar
Re: Rear Axle Codes
It looks like code HE is a 3.07:1 ratio. It is still a good idea to pull the cover and put some fresh oil in. You can check the no's stamped in the ring gear at the same time.
Old 04-09-2013, 07:44 PM   #9
rt65s
Re: Rear Axle Codes
Can you tell what year from this code HE121w
It has a hole cast into the pumpkin for the panhard bar.
Old 04-09-2013, 07:52 PM   #10
john
member #16
john's Avatar
Re: Rear Axle Codes
Originally Posted by rt65s View Post
can you tell what year from this code he121w
it has a hole cast into the pumpkin for the panhard bar.
1965-1966
Old 04-09-2013, 11:59 PM   #11
rt65s
Re: Rear Axle Codes
Do you know when the 12 bolt rear end went to 30 spline axles?
Old 04-20-2013, 03:03 PM   #12
rt65s
Re: Rear Axle Codes
Found another 12 bolt posi but want to know what year. This is stamped on the pass. side tube: HC0829W The ring gear is stamped 381778 11 41 GM 8 66 1. Any help would be great. Thank you for your help.
Old 04-20-2013, 04:02 PM   #13
SS Tim
SS Tim's Avatar
Re: Rear Axle Codes
67 3.73 posi
Old 07-02-2013, 06:56 PM   #14
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Rear Axle Codes
I am trying to ID a rear end housing that I have. The code on the passenger side tube is:
HA02 17W
On the driver side I found an 88 stamped on the tube.
I don't care what gears or if it is a posi, I am just looking for the year model. I know it is a 12 bolt, with an Eaton Posi carrier and 4.10 Richmond gears. The housing appears to be a 65-72 since there are torch marks at an angle from cutting off the pads on the tubes.
Any info on this would be great.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-02-2013, 07:09 PM   #15
SS Tim
SS Tim's Avatar
Re: Rear Axle Codes
HA 65-69 3.73
0217 built February 17th
W by Warren Gear
Old 07-03-2013, 08:50 AM   #16
aggie91
aggie91's Avatar
Re: Rear Axle Codes
Thanks Tim!
Karl
The LST Challenge:
Old 09-01-2013, 09:08 PM   #17
thekid54
Re: Rear Axle Codes
Any help with this code: RAC 054W81? Thanks in advance!
Panel Beaters C.C.
thekid54 is offline   Reply With Quote
Old 09-01-2013, 09:27 PM   #18
SS Tim
SS Tim's Avatar
Re: Rear Axle Codes
How does a 72 CA30/PA30 4.57 open HO72 sound to you?
Old 09-01-2013, 10:00 PM   #19
thekid54
Re: Rear Axle Codes
Hmm, my rear end is a 12 bolt & currently has a 2.76 in it (I understand it could have been changed somewhere along the line) and I have no idea where it came from. HO72 looks like a 10 bolt. Pardon my ignorance, but what's a CA30/PA30 model?
Panel Beaters C.C.
Old 09-01-2013, 11:58 PM   #20
SS Tim
SS Tim's Avatar
Re: Rear Axle Codes
Sure would have been easier if you had mentioned that up front.
The application I gave was for a 72 C30 1-ton truck or a P30 1-ton step van. Since you have a 12 bolt (now stated) I spent some time looking for you. GM parts wiki is showing RAC as a 78 C10 12-bolt open 2.76 axle. There very well might be others.
Here are some links if you want to look around. Sorry, my connection is not fast enough nor do I have the time for most non-67-72 requests that are outside stock applications.
http://www.gmpartswiki.com/getpage?pageid=60434
http://www.gmpartswiki.com/getpage?pageid=60426
Old 09-02-2013, 02:17 AM   #21
thekid54
Re: Rear Axle Codes
Sorry for the lack of info, I didn't realize the code would span across two different types of axles. Thanks a lot for the info!
Panel Beaters C.C.
Old 10-10-2013, 07:01 PM   #22
davbowen
davbowen's Avatar
Re: Rear Axle Codes
mine has code HE807W. I think it a 65 with 3.73 gears
can someone verify this. it's my 63 1/2ton and i'm looking to rebuild it. don't know if its 17 or 30 spline.
davbowen is offline   Reply With Quote
Old 10-10-2013, 07:58 PM   #23
john
member #16
john's Avatar
Re: Rear Axle Codes
Correct 1965 c-10 w/3.73:1 ratio.
Old 10-10-2013, 08:58 PM   #24
davbowen
davbowen's Avatar
Re: Rear Axle Codes
thanks john, that's good news. it should have 30 spline axles in it. I assume that the carrier in it will only fit 3.73 and up gears, 4 series. but since i'm looking for a posi I should be able to get a truck unit for 3 series gears, correct. the 3.73 are just to much for the th350. thinking about a 3.08 or a 3.42 to calm it down a bit.
Old 04-08-2015, 10:34 AM   #25
First c10
First c10's Avatar
Re: Rear Axle Codes
I know this is an old thread but didn't want to start a new thread.
I picked up this rear end to rebuild for the truck. I know it is a 12 bolt but can someone decode the stampings please?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
