Old 02-02-2010, 05:55 PM   #1
115-K10
115-K10's Avatar
4x4 vs 2wd power steering
I am converting from manual to power steering on a '67 4x4 (k10) chassis. Is there a difference b/w the 2wd and 4x4 steering box and/or pitman arm? If anyone has photos it would be a great help.
I know the '67 chassis will also need an adapter plate. Who makes the best one on the market or do you know anyone who has an extra one?
Thanks for the help!
The chum Bucket - SWB K10 Restoration - http://67-72chevytrucks.com/vboard/s...d.php?t=329775
1971 SS454 Monte http://www.hemmings.com/mus/stories/...feature14.html
1970 - Monte Carlo Convertible, LS6, L89, M22 Build
http://www.firstgenmc.com/ubbthreads...=360236&page=1
1970-SS454 Tripe Black - Barn Find
http://www.firstgenerationmontecarlo...=421201&page=1
115-K10 is offline   Reply With Quote
Old 02-02-2010, 08:55 PM   #2
JimKshortstep4x4
Re: 4x4 vs 2wd power steering
The 2 wd and 4 wd boxes and pitman arms are different.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-02-2010, 10:18 PM   #3
Mike C
Mike C's Avatar
Jim is correct. Before you proceed, Google "crossover steering" and read up on that. Way too much info for me to try and post.
If you are starting from scratch and you are contemplating swapping in a disc brake axle (or you already have) this might be a good time. 2x4 boxes are usually cheaper used than 4x4 and much less likely to be worn out.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-03-2010, 06:51 PM   #4
115-K10
115-K10's Avatar
Thanks for the pointers on the crossover conversion. After looking it up on google it looks like a great option for lifted trucks. I am going to basically stay at stock height so I think I should just try the 4x4 box/pitmen arm swap. I am also running a plow and not sure if the plow frame will interfere with the crossover.
Old 02-07-2010, 11:30 AM   #5
msgross
msgross's Avatar
I would find a donor front axle too... might as well go for disc brakes on your 67... My money pit project is going that route... the newer axles all bolt up.
Steering will require a new 4WD box, pitman arm, and if you go with a newer axle then get the drag link, steering arm etc...
I suggest to find a $400 donor 4WD and rob all of the parts that you need, sell the rest for scrap.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-07-2010, 11:46 AM   #6
doug70
I need some more info on this. On project Grasshopper, I am using parts from several donor trucks. My plan was to use the steering gear box from the 91 2wd suburban and put a 4" drop pitman arm on it. Will that work?
Doug
68 CST 396, 60K original miles
70 Longhorn project
72 Stepside (150% complete)
67 Stepside project
71 RS Camaro 90% done
71 BB Corvette 50% complete
78 K5 project
doug70 is offline   Reply With Quote
Old 02-07-2010, 02:00 PM   #7
msgross
msgross's Avatar
2WD's had gear boxes and pitman arms that moved left to right, 4WD's moved front to back.. not sure how long that was true but I bet it went into the 80's like that.
The Garage:
